20 Most Recent Samsung Digimax S600 / Kenox S600 / Cyber 630 Black Digital Camera Questions & Answers
2answers
Drivers d'installation compatible avec Windows 7
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
9/21/2015 2:52:57 AM • Samsung Digimax... • Answered on Sep 21, 2015
Samsung camera digamax x600 cyber
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
10/4/2014 11:31:15 PM • Samsung Digimax... • Answered on Oct 04, 2014
When turned on camera beeps 3 times & the zoom
Does it take standard disposable batteries or a rechargeable pack?
If the first, check they are inserted correctly as per the illustration in the battery compartment or instruction manual section on inserting batteries.
If the second type, recharge the pack.
If problem continues check Troubleshooting section of manual or online at Samsung's website.
9/20/2011 9:03:06 AM • Samsung Digimax... • Answered on Sep 20, 2011
0answers
Hi i have problem with
I have had this problem before as well. Your camera only accepts SD cards, not SDHC.
Be careful an look to make sure it does not say SDHC on your next purchase.
You camera manual can be found here.
3/26/2011 12:58:47 PM • Samsung Digimax... • Answered on Mar 26, 2011
Camera keeps telling me to
Perhaps you card is not inserted or it is full.
12/15/2010 7:31:18 PM • Samsung Digimax... • Answered on Dec 15, 2010
Computer cannot read sd from camera
Does anything happen on your computer when you plug in your camera?  Make sure the camera is turned on if not.  You may need to press OK on the camera also when it is plugged in.
5/19/2009 8:47:44 PM • Samsung Digimax... • Answered on May 19, 2009
Images are to bright even after reset
This can be a broken shutter cable inside the lens. Toes it still make the "click" (not from the speaker)?
3/16/2015 11:44:14 PM • Samsung DigiMax... • Answered on Mar 16, 2015
How do I use the focus
be sure your lense and autofocus sensors are clean first thing.. then push the take picture button half way and it will autofocus. Pressing hte take picture button fully then will snap the picture.
1/3/2015 4:07:56 AM • Samsung DigiMax... • Answered on Jan 03, 2015
How do I get camera to recognise new card. It asks to configure,I press ok, it tells me to check card.It only goes in one way.How do I fix?
If you have a computer, insert it into the card reader,l select it and format with your computer
12/28/2014 3:20:00 AM • Samsung DigiMax... • Answered on Dec 28, 2014
What is the card type which can be inserted in Samsung Digimax 401
The 401 takes MMC and SD cards, 2GB or smaller.
10/6/2014 2:48:17 PM • Samsung DigiMax... • Answered on Oct 06, 2014
How to use a camera?
You should be able to follow the instruction available at this website. http://downloadcenter.samsung.com/content/UM/201301/20130129135843169/WB30F_English.pdf
7/31/2014 12:11:24 PM • Samsung DigiMax... • Answered on Jul 31, 2014
Samsung wb500 drivers windows xp
You need to install Intelli-Studio, Please view the following guide how to start this installation. http://skp.samsungcsportal.com/integrated/popup/FaqDetailPopup3.jsp?cdsite=uk&seq=1038212 Or download Intelli-Studio here: http://samsung-intelli-studio.updatestar.com/
5/25/2014 3:45:27 PM • Samsung DigiMax... • Answered on May 25, 2014
Taking picctures outside they come out completly white and inside they are fine.
Not sure what type or model of camera you have. But most camera's have a Mode dial. The best thing to do is to turn that dial to the little green camera logo. That is the automatic mode. If you have chosen the moon and star, you only can make pictures in bad light situations.
12/9/2013 3:51:59 PM • Samsung DigiMax... • Answered on Dec 09, 2013
Usb usb data transfer cable
Have you considered NOT connecting your camera to your computer?The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
7/8/2013 12:10:41 AM • Samsung DigiMax... • Answered on Jul 08, 2013
Samsung Digimax S600 / Kenox S600 / Cyber 630 Black Digital Camera Logo
Popular Tags
12 questions posted
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
DigiMax Samsung
  • DigiMax Samsung
Most Popular Question
drivers dinstallation compatible avec
  • Cameras
