20 Most Recent Kodak EasyShare MD853 Digital Camera Questions & Answers
Camera screen is black no image appears to view to take a picture??
Time for a new camera perhaps ? Sreen is faulty, most likely and fixing may be too expensive.
9/14/2014 7:36:50 PM • Kodak EasyShare... • Answered on Sep 14, 2014
Plug camera into computor and
Try NOT plugging your camera into your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
6/10/2011 6:19:41 PM • Kodak EasyShare... • Answered on Jun 10, 2011
Someone gave me a Kodak EasyShare MD853 camera but
You can download the same CD here:
http://support.en.kodak.com/app/answers/detail/a_id/36670/selected/true (Windows)
http://support.en.kodak.com/app/answers/detail/a_id/16433/selected/true (Mac)
If you still can't download pictures, do it the manual way:
http://www.chriscamera.com/downloadingphotos.htm
Hope this helped you!
Be Sure To Rate macapplezoo 100% Or Whatever You Think I Deserve!
5/31/2011 7:34:04 PM • Kodak EasyShare... • Answered on May 31, 2011
Can not get pictures to
The share button supposedly allows you to easily upload photos to a social networking site, once you have it set up properly. See this page from the user guide:
http://resources.kodak.com/support/shtml/en/manuals/urg00745/urg00745c4s5.shtml
5/19/2011 9:37:25 PM • Kodak EasyShare... • Answered on May 19, 2011
When I connect the camera to my computer, it is
Try NOT connecting your camera to your computer.
5/1/2011 12:17:32 AM • Kodak EasyShare... • Answered on May 01, 2011
Cannot upload pictures from my camera to computer
Consider NOT connecting your camera to your computer.
3/31/2011 5:26:40 PM • Kodak EasyShare... • Answered on Mar 31, 2011
Camera say lens obstructed
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
Make sure your batteries are fully charged.
Remove the batteries for 10min. Replace the batteries and see if the problem persists.
Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
You can also visit http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Regards
15073327
2/10/2011 6:59:26 AM • Kodak EasyShare... • Answered on Feb 10, 2011
What type of battery charger does it need
These battery types are compatible with your camera...
Rechargeable Batteries:
* Li-ion Battery Special Size Lithium Batteries: Uses 1 Li-Ion (3.7V, 720 mAh) KLIC-7001
Visit KODAK Store for a complete list.
Hope this helps (remember to rate thsi asnwer).
12/15/2010 3:59:15 PM • Kodak EasyShare... • Answered on Dec 15, 2010
Lens error 1,of,1,0,0 it never happens! :s
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
11/23/2010 11:37:03 PM • Kodak EasyShare... • Answered on Nov 23, 2010
My kodak md853 was dropped and is now showing a
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/30/2010 7:09:04 AM • Kodak EasyShare... • Answered on Sep 30, 2010
Turn on and get lens error 10f,1,0,0
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
9/12/2010 3:32:20 PM • Kodak EasyShare... • Answered on Sep 12, 2010
My camera's (Kodak MD853) flash does not work.
evironmental settings for shutter speed and duration day or night or subject motion. maybe it is set for night in a dim but lighted place.
8/20/2010 1:03:30 AM • Kodak EasyShare... • Answered on Aug 20, 2010
Message says lens error and
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
8/17/2010 8:37:08 PM • Kodak EasyShare... • Answered on Aug 17, 2010
Battery dont work and i want to use my camara
You should operate the camera off of a battery, but if you connect a power supply to it of the appropriate dc voltage, it should work as if it were in a store.
7/17/2010 9:55:31 AM • Kodak EasyShare... • Answered on Jul 17, 2010
Reddish w/ horizontal lines on pictures when review on its LCD.
You no need to fix this problem. This is a CCD failure and in some cases had been subject to a recall.Contact Kodak support this may be one of the recalls and replacement camera could be on its way. They will do it for free of cost.
Thank you !!
7/13/2010 5:17:08 AM • Kodak EasyShare... • Answered on Jul 13, 2010
I was taking pictures and i dropped my camera and
The lens unit needs to be serviced, possibly marginal repair, so if you look at the lens and it seems to be crooked, you could try GENTLY straightening it , but this may make it WORSE! Do not push it in, try to pull out the side that is already pushed in, if you get what I mean.
Otherwise take it to a repairer.
6/9/2010 1:11:46 AM • Kodak EasyShare... • Answered on Jun 09, 2010
Kodak EasyShare MD853 Digital Camera Logo
Popular Tags
42 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
lens error 1 1 0 0 never happens s
  • Cameras
