20 Most Recent Acer CI-6330 Digital Camera Questions & Answers
I need to use sd card more than 1 G
The camera works with SD cards, which max out at 2GB. It will not work with higher-capacity SDHC cards.
1/6/2013 12:08:57 AM • Acer CI-6330... • Answered on Jan 06, 2013
I have a zoom error!what i have to do?
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
1/7/2010 10:04:51 PM • Acer CI-6330... • Answered on Jan 07, 2010
Acer B1-810. My Windows 10 PC recognizes the tablet in MTP mode but reports that most of the folders are empty. It can't find most of my photos, any of my podcasts or any of my documents. ???
copy files to computer. save in gallory files windows will ask you what to save in PIF or JARAS then it should be readable
2/13/2018 12:55:00 AM • Acer Cameras • Answered on Feb 13, 2018
Necesito todos los drivers asignados para el Acer TravelMate 3010 (3012WTMi)
https://www.acer.com/ac/en/US/content/support for drivers and support
3/7/2017 5:26:52 PM • Acer Cameras • Answered on Mar 07, 2017
I have an Acer a3 a10.how do I put my photos on to see card from tablet memory?
Since this is a query regarding a tablet, not a camera, you may find more help if you post it in the Tablets forum.
10/8/2016 8:26:08 PM • Acer Cameras • Answered on Oct 08, 2016
I forgot my yahoo password
Click the "I can't access my account" link on the Yahoo sign-in page.
9/30/2014 4:27:31 PM • Acer Cameras • Answered on Sep 30, 2014
Win7 64 bit webcam driver for mikomi webcam
9/10/2014 9:11:49 AM • Acer Cameras • Answered on Sep 10, 2014
How do i copy images from the internal memory to the memory card
CONNECT YOUR CAMERA WITH COMPUTER THROUGH A HDMI CABLE
8/16/2014 12:04:12 PM • Acer Cameras • Answered on Aug 16, 2014
Can't get bushnell trail camera 8mp to come on
Use lithium (non-rechargeable) high energy batteries for best results. This is clearly a power supply problem. If it doesn't work, send it back for replacement. If the batteries are self-contained, ensure they are fully charged using the charger supplied with the camera. Remember, rechargeable batteries are only good for a maximum of two years. Cameras, in general, do not work well with rechargeable batteries as the voltage is less, i.e.; 1.25 volts vs. 1.5 volts per AAA/AA/C or D size battery.
8/27/2012 6:36:39 AM • Acer Cameras • Answered on Aug 27, 2012
I want to reinstall my
Be more clearly about your webcam model!
5/9/2011 1:46:26 PM • Acer Cameras • Answered on May 09, 2011
How can i install my
Here is a tip that I wrote about how to find the manuals, drivers, downloads and support for Digital Cameras.
Digital Camera Manuals, Drivers, Downloads, and Support
heatman101
4/23/2011 3:08:47 AM • Acer Cameras • Answered on Apr 23, 2011
I have a problem with my yashica EZ F1230 digital
i too facing the same problem with same model of camera
3/28/2011 1:41:33 PM • Acer Cameras • Answered on Mar 28, 2011
Hi my webcam is not
What Operating System are you using? I.E. Windows Vista or Mac OSX?
First you can make sure your cord on both ends is plugged in fully? If so, assuming its USB, plug it into another port. Restart the computer and then try it again. If this doesnt work, check to see if the software that came with the device is installed. Try uninstalling the software and reinstalling it again. This will hopefully refresh the driver and find the device if somehow lost it.
Hope this helps.
3/6/2011 3:07:31 PM • Acer Cameras • Answered on Mar 06, 2011
I forgot my password of yahoo email
Use this - https://edit.europe.yahoo.com/config/eval_forgot_pw?new=1&.done=http%3A//mail.yahoo.com&.src=ym&partner=&.intl=uk&pkg=&stepid=&.pd=ym_ver%3d0%26c=&.ab=&.last=
3/3/2011 10:08:14 PM • Acer Cameras • Answered on Mar 03, 2011
I want to put a
Yes you can, check your power settings and in there, you can put a timer whether sleep mode or timer when the unit will be turned on or off...
2/13/2011 12:54:04 AM • Acer Cameras • Answered on Feb 13, 2011
How to edit picture?
you can use picasa for pc for free
or you can edit in your mac with iphoto
12/14/2010 6:33:07 AM • Acer Cameras • Answered on Dec 14, 2010
How do I use my
Did you install the ACER crystal eye utility? If not please get me the model number of the laptop(ex: Acer Aspire 1230us) and I will help you find the utility and resolve your problem.
Sai.
12/5/2010 2:12:20 PM • Acer Cameras • Answered on Dec 05, 2010
How to take picture from
Did youmean to transfer? if so use the card into the cardreader to transfer as it detects.
If otherwise please specify in details your question.
9/29/2010 7:15:24 AM • Acer Cameras • Answered on Sep 29, 2010
Acer CI-6330 Digital Camera Logo
Popular Tags
4 questions posted
Top Acer Cameras Experts
Ngoro
Tony Parsons
Tony Parsons
kelly
kelly
Are you an Acer Camera Expert? Answer questions, earn points and help others
View Most Popular
Acer Cameras
  • Acer Cameras
Most Popular Question
need use sd card more 1 g
  • Cameras
