20 Most Recent Sanyo HDP-M3000 MP3 Player Questions & Answers
0answers
Does anyone know how do download the sanyo music
Hi you can get it from sanyo from there website i got it from here http://jp.sanyo.com/icr/english/index.html hope this helps
1/30/2011 2:14:56 PM • Sanyo HDP-M3000 ... • Answered on Jan 30, 2011
How do i get my
Hi Gloria788 just plug it in with the supplied usb cable that came with it and use musicfilemaster which you can download from sanyos site for the m3000
1/29/2011 1:43:58 PM • Sanyo HDP-M3000 ... • Answered on Jan 29, 2011
Hello, I formatted the M3000 with Ubuntu Linux, and... i'm stupid
Take your Sanyo back to Linux box, hook up the USB cable, and then mount it.
Copy the files that you want to keep on to the $HOME directory on Linux.
Next, from a terminal, run
sudo fdisk -l
to display all the mounted filesystems on the computer.
It might be /dev/sdb1, or /dev/sdc1 You should be able to pick out the M3000 as its hard disk size is 6.0 GB. Let's assume that the USB drive is on /dev/sdb1
Re-run the fdisk command.
sudo fdisk /dev/sdb
(press m to get the help menu).
Recommend that you choose d to delete a partition,
then n to create a new partition
when asked about the code for the new partition, use b -- this corresponds to Windows 95 FAT32 file system.
Don't forget w to write the new partition definition out to the USB drive.
Lastly q to quit fdisk.
Once you exit fdisk, remount the M3000 and make sure that you copy your files back on to it.
All Linux and Windows systems should be able to recognize your drive now.
3/19/2010 3:15:02 AM • Sanyo HDP-M3000 ... • Answered on Mar 19, 2010
When i transferred files from my computer to my
  • probably there may hav occured an error in transfering
  • click the button near the player to switch it on
  • install the player in pc once again
7/18/2009 12:07:10 PM • Sanyo HDP-M3000 ... • Answered on Jul 18, 2009
How much would it cost to service a 1960's sanyo reel to reel video recorder?
Video recorder? Please state model number.
12/10/2023 8:35:38 AM • Sanyo Audio... • Answered on Dec 10, 2023
I cannot get sound on my Sanyo RM-7024 cassette/radio player. What do I need to do?
from description given the unit is defective.
7/14/2023 5:26:09 PM • Sanyo Audio... • Answered on Jul 14, 2023
Sanyo TRC 1149 winding and playback faults
Hi,\015\012\015\012I'm sorry to hear that.\015\012\015\012This is a common fault on cassette decks and can be caused by a number of things.\015\012\015\012The most common is the motor being seized or worn.\015\012\015\012If the motor spins when you touch the belt then the problem lies in the drive mechanisms.\015\012\015\012There is a good chance that the drive belt has perished and needs to be replaced.\015\012\015\012If the deck is drawing too much current when you switch it on the fuse will blow.\015\012\015\012If the fuse is fine and the deck runs for a few seconds before cutting out then the problem could be one of the capacitors in the power supply.\015\012\015\012If the deck is more than 10 years old then it may be time to replace the capacitors.\015\012\015\012You can do this yourself if you are a little bit handy with a soldering iron.\015\012\015\012That's about it really.\015\012\015\012
11/5/2022 1:11:06 PM • Sanyo Audio... • Answered on Nov 05, 2022
I need the User Manual for the Radio Clock SANYO RM 5060
https://www.manualslib.com/manual/1069169/Sanyo-Rm-5090.html
7/10/2022 2:34:15 PM • Sanyo Audio... • Answered on Jul 10, 2022
Hi i have a sanyo tp825du turntable and the platter keeps spinning when tone arm is at rest. What is the issue that causes this and what do i need to do to fix it. Thanks guys.
When the tone arm returns to its base it should contact a small micro switch which turns off the motor. Going underneath the platter you should find the switch, either bent out of place or broken.
6/5/2021 3:43:35 PM • Sanyo Audio... • Answered on Jun 05, 2021
Cannot play wmv or MP4 files - SANYO DMC 2040
You most likely are not meeting the specs required by the player. Check the manual on the cd for the specs the player can resolve or use the converter on the cd to convert your mp4's wmv to meet the specs.
5/7/2021 10:46:02 AM • Sanyo Audio... • Answered on May 07, 2021
Pairing Sanyo tv with wireless speaker? Please
Is your tv compatible with wireless speakers?
3/7/2021 11:57:57 PM • Sanyo Audio... • Answered on Mar 07, 2021
I have a Sanyo universal remote and a durabrand home theater ht-400. How do I program the remote for it?
Use code search on your Sanyo URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
12/21/2020 4:48:53 AM • Sanyo Audio... • Answered on Dec 21, 2020
I have a sanyo cassette deck model Rd r60 circa 1983. I have purchased new belts for the deck due to the old belts having become liquid. I have cleaned all the pulleys but need to replace the belts with new ones. Does anyone have a belt diagram of the machine or know where I may find a diagram? Any help would be greatly appreciated.
There might be a diagram but I haven't seen any belt fitting diagrams at all, merely the odd exploded view. Replacing cassette belts is as much fun as a jigsaw puzzle - you keep removing screws and parts until you can fit the belt and then you reverse the process...
7/4/2020 8:03:49 PM • Sanyo Audio... • Answered on Jul 04, 2020
Sanyo HDP-M3000  MP3 Player Logo
15 questions posted
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Audio Players & Recorders
Most Popular Question
get
  • Audio Players & Recorders
