20 Most Recent
Konaki CDT-4 MP3 Player Questions & Answers
How I transfer music from my computer to the IPOD
you should convert the format of your music to suit for your IPOD. i think
Video Download Studio can help you with this.
Use http://www.downloadvideos-convert.com/download-videos-music
1. Download Video Download Studio, install it.
2. Go to the interface, you can download (Automatic capture) the YouTube video there directly. Tab Download to
Convert, you can also click "Add" button to upload the videos from computer. You can also edit video by trim and crop
functions.
3. After the video display on the Video Download Studio, click "Profile" and choose "General video", then select an MP4
format. Set destination file, clicking Convert button to complete the task.
Not only convert video to MP4, but also support batch conversion. Safe and easy to operate. No Viruses, No Spyware, No
Adware. Do not hesitate. Have a try!
Need help on downloading music and others things
When your device is connected, go to my computer if you are using a pc, then you should see a drive listed with your device on it. Double click to open up the folder. You should now see your mp3 folder. Leave this window open. Now take and open up your music folder and drag the songs from the music folder over to the drive folder with your device on it.
If your device is not being detected, then you will need to download the latest drivers which can be downloaded from the manufacture's website and are more up to date then the driver cd.
SONGS
Music will only play if they are in the correct format (MP3) . Are you using Itunes? or similar, if not and you are simply taking songs from a CD or your PC library they are not MP3 bfiles ut audio files instead they will not play. Software like Itunes converts songs into MP3.
Can't turn it on or off
u have to slide the button to where it reads on/off and hold it for about 5 seconds and then release button!repeat these same steps when turning the device off1
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
