20 Most Recent
Emerson BAR901 MP3 Player Questions & Answers
Says disk error
try and format using hp format tool. i would do it in safe mode. failing that i would go disc management and change the drive path letter. hope this helps you out
Download music from my mp3 to my computer
Hi, First use a usb cable to connect your mp3 player to your
computer. Next a box will pop up and ask you what you want to do, click
the option that says "open in new folder" this will open all the
contents of your mp3 player. Next click start(on your task bar) and
search, click to search your hard drive (most likely drive C) and click
the search for box and click music/audio. This will search for and find
all available music files on your computer, when the search is done find
the songs you want on your mp3 player, highlight them and drag-and-drop
them into the folder that you opened for your mp3 player. Using this
method you do not need any software or special training at all, it's
easy fast and to the point. Now for free music I use a program called
Blubster (look in Google) download it and download your songs for free!
have a nice day!!
How do i turn it on help me?
i think this is what my sister who is 8 has...just hold the play/pause button down for a couple seconds try that
It won't show up on my windows media play what do
OK see if the following works:
1.plug your pen drive 32gb in your computer.
2.then open Control panel.
3. open administrative tools.
4.open Computer Management
5. a window label computer management will appear.
6. click disk management
7.locate you pen-drive and select delete partition or format it fat 32 or other format convenient for your usage.
ok
hope this will help
cheers
uttam
I added music and it still wouldn't work?
a bit more detail would help - like what is the hard ware you're talking about, is this am MP3 player, a PC / Mac. Are you trying to play this music (is it MP3 CD or what) through a media player, if so which one. Come give us a chance to help. Think!
Everything in a different languagehow do i chage
Try to navigate back to the "Choose Language" setting in the "Settings" menu.
If you aren't able to find it, then restore your ipod, and you will be able to change your language.
If you don't want to do that, then use an internet translator to guide your way to the language section.
Im tryna get songs on my mp3 player and i dont no
you can use websites like itunes.com and get the music then use windows media player to sync the songs to your mp3 player just load the music you get into the windows media player library and then drag them over to a sync window and click on the sync button :)
I don,t know how to put music on my mp3 player
Windows Media Player has the Sync tab. I believe that WMP 9 does. But not 10. Either way, you can just open up the player in the My Computer folder. Then copy and paste any music files you have.
Wont let me acess my music
There is no difference of systems in color. You should get it either checked out or tell me the full details so i can tell you what is wrong because mtp something isnt going to help me out much.
Emerson mp3 player frozen
That means it is working!!! If you have your mp3 on at the same time charging it is working on recharging it. All you have to do now is download stuff to it!!!
How to turn on my Emerson Mp3 Player
hey man, i had the same problem as u and the "solution" was to press and hold any button some seconds until the player turn on
yes, its really annoying but it worked on me ^^
Emerson MP3 player-like BAR901
If you own the data cable for the device you may not need the software. All mp3 players may act as file sharing devices. The software included with these devices is usually more for convenience and not really needed. Plug your data cable in to your computer and wait for it to recognize your device. Open My Computer and near the C:\ drive you'll see a new disk appear. Most likely it will be named E:\ or F:\ . Double click to open it. This will tell you if there is any files left on the device. I'm not familiar with that brand, make or model but this is pretty much industry standard. If for some reason the device moved your mp3 files outside of the typical music folder simply drag them back in. :) Then it will be able to read the files correctly again. :)
Mp3
Try to format -
The below was copyed from an earlier post of mine.
Over a period of time your info can get corrupt from transering music back and forth.
To format plug it in to usb.
Go to my computer
It shows up as a removably disc, usually drive f:
Right click on drive f: (or the approriate drive) and click format.
Let me know what happens, you will have reload the player, also try bypassing the software you are using to tranfer, by opening up drive f: and clicking and dragging your music into it , or you can copy and paste it into drive f:
L8R
