20 Most Recent
Nokia 5070 Cell Phone Questions & Answers
Restriction code
You can get restriction code for your Nokia 5070 mobile phone from
Onlinegsmunlock.com at reasonable price by specifying the details like country name,current network provider and IMEI number.
Restriction code
You can approach
Simpleunlocking.com
and get the restriction code for your Nokia 5070 mobile.You need to
specify the country,locked network and based on the availability get the
unlock code.You can visit
Mobileunlockguide.com and get free unlock instructions to aid in the unlock process.
My pro is hard reset of nokia5070
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Can you help me unlock my NOKIA 5070
Is if only u ar sure that ur nokia phone is origina then u cn go 2 ur security setting and and u we see change access code change security code and dia ,12345,an u we see now code and comfirm code, now ur problen is solve bt make sure u put de code u we nt forget.
I forgot my security code
hi friend you are asking for security code which you forgot.
so there is a 2 way to unlock your cellphone:
FIRST WAY:
show your phone on any mobile repairing shop because its a problem of software ,means you have to reinstall your operating system .and they will charge you about $2 for this.
SECOND METHOD:
go on this website and make account and then you can get unlock code.....
www.unlock-zone.com
or just provide me your detail i'll give you
1.country
2.service provider
thankyou
354830019216102 restricted code no-?
Nokia Restriction Codes are used to remove restrictions added to a Nokia phone by your original carrier so it will only work with their network. It is also known as an unlock code or an unlock password.
You can get the unlock code through online..........i will suggest the website
Unlock-Zone.com which is doing good service .....you can approach this website.
Cannot connect to internet how
just call the servise provider or the network provider to activate gprs or edge. ask for settings and they will provide you. save the settings in your phone . activate the right settings and use it . hope your problem is solved. happy surfing.
