this will get you back to factory default and take you through wizard for setup.
To perform a hard reset 1. Remove the back cover. 2. Press and hold the SOFT KEYS, then use the stylus to press the RESET button located below the battery compartment. 3. Release the RESET button, but continue pressing the SOFT KEYS until you see this message on the screen: 4. Release the SOFT KEYS, then press TALK/SEND to perform the hard reset, or press any other button to cancel the reset. This operation will delete all your personal data, and reset all settings to manufacturer default. Press Send to restore manufacturer default, or press other keys to cancel. Clear Storage Another way of clearing the device storage and reset all settings back to factory default settings is to use the Clear Storage feature. You will lose all your data and files on the device storage when you use Clear Storage, so make sure to do a backup first. Important If Encrypt files placed on storage cards is or was enabled before, then backup all files from the storage card before using Clear Storage, hard reset or updating the ROM system software. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card. 1. Tap Start > Settings > System tab > Clear Storage. 2. Enter “1234”, then tap Yes. Your device restarts and displays the Quick Setup Wizard
If you using WinXP then you need ActiveSync 4.5, if Vista then you need WMDC 6.1. First install software and then follow instructions how to connect your phone.
yes. you must first register the device with your computer through the bluetooth manager. once they are linked you can transfer the install cab file by blutooth, but you must actually install the file from your device. please rate me if this helps. thanks and good luck!
here u'll have *.cab files which can be downloaded to the PC and from there can be transfered to the HTC through the same cable that is for charging diconnected from the charging unit and connect to the USB port
save the files to the memory card / storage card
and from the file manager on the phone go to the folder where you have saved the cab files and clicking on them would start the installation process
Only Telus can unlock it and only if the rent to own contract is paid off. If you take it to a third party unlocker, Telus can still lock it on you by using the IMEI number.I would urge you to edit out your IMEI number as it can allow the unscrupulous to clone your phone and make calls at your expense.
iPubsoft Studio recently announced that it released its new software -- iPubsoft Android SMS+Contact Recovery for Android program, a new program that helps HTC users retrieve lost message from HTC device, The program includes significant improvements like simplified operation optimization, can scan text message, contacts file.
Simple Tricks to Retrieve Deleted SMS Messages from HTC Phones
You can try GT Recovery for Windows!
GT Recovery for Windows is a professional data recovery for Android phone or tablet. It can restore deleted photos,videos,audios,documents from Android SD card and internal memory. Whenever you lost important pictures or deleted photos by accident, you can use it to scan and recover the images on your Android devices.
Here are the steps to recover deleted data on Samsung Galaxy S4.
With this way you can recover deleted data on any brands of Android device such as Samsung, HTC, Huawei, Sony, Motorola, Lenovo, LG, Sharp, etc.
Google+:https://plus.google.com/communities/109657948177651590858
Facebook homepage:https://www.facebook.com/GT-Recovery-for-Windows-527139864132104/
Download Link:http://www.gtrecovery.net/
