20 Most Recent
Motorola Mobility RAZR v3xx Cell Phone Questions & Answers
I have a Motorola v3xx and is asking for a subsidy
Well right on WA page there is a link to here
http://www.cellunlocks.com/they claim to do it over the air, for $5.00. If thats true not sure you could find it for much less than that. I unlocked my razr using a cable and a web site that charges $25.00 for access to thier server once you install thier software. But it does work. Here is the link to that site
http://www.cell-unlock.com/ However first you will need to be able to connect your phone to your computer. Then download thier software and run it in test mode. It will report back if they can unlock your phone. If it says it can, pay the $25.00 and let thier software do the work.
Dont forget to rate me thanks in advance......
2/9/2011 10:14:30 AM •
Motorola...
Answered
on Feb 09, 2011
Mobile
you should active your gprs and send a request to your network for internet setting by telling the network your cell model and they will set your settings and in this way you ca set your java
6/5/2010 10:21:44 AM •
Motorola...
Answered
on Jun 05, 2010
Remove camera
open up the back of your v3.take out the battery..
then remove the 4 little rubber screw plugs on the 4 corners of the screen side of the flip/there are 4 little star type screws in there.remove them remembering what hole each screw came out of.some v3s have different size screws in the holes.then you'll see the flat ribbon cable going from the camera to the pc board of the screen.remove it and gently work the camera out of its holder..be careful.use a flat type screw screw driver to work it out.
5/25/2010 8:47:01 AM •
Motorola...
Answered
on May 25, 2010
Motorola V3XX not charging
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
5/21/2010 7:20:39 PM •
Motorola...
Answered
on May 21, 2010
My motorazar v3 xx don't charge when it is in my
Hi
There's a driver that you need to download and install in your laptop so it will charge from it. click
HERE and download the software driver and check if its compatible with your operating system by checking system requirements.
Hope this helps
4/2/2010 12:51:54 AM •
Motorola...
Answered
on Apr 02, 2010
I have a motorola v3xx cell phone that will not
Sound like your phone is done for.
But try this first.
Remove the battery, remove the simm card. Wait 10 minutes.
I can assume the battery is good (as that's the #1 reasons for phone problems) Unless you can test the battery with a meter or use the battery in an identical phone don't assume its good.
Then replace the simm, put tha battery back in and give it a try.
Doesn't power up.?? Head on over to the phone store of your choice. Good luck.
1/21/2010 1:38:01 AM •
Motorola...
Answered
on Jan 21, 2010
