20 Most Recent Sony PSP-3000 Silver Console Questions & Answers
2answers
I want to buy a PSP.which version should i
Well the best option would be the psp 3000 because it has a better screen width, has a enhanced graphics processor and can play Flash Videos i think (Newgrounds videos). It also is lighter than the rest of them
6/13/2013 9:37:32 AM • Sony PSP-3000... • Answered on Jun 13, 2013
Psp3000 overheat and battery drained fast
get a new battery the battery is too old
10/8/2012 2:50:22 AM • Sony PSP-3000... • Answered on Oct 08, 2012
How do i charge my psp battery
Plug the charger into the wall. Plug the other end into the spot on the PSP with the yellow outline. Check for an orange light. If it's on, let it charge until the light turns off. It it's not on check connection. If it's still no charging, take out the battery and put it back in. If it's still not charging remove the battery and try to turn it on. If it will no start, your PSP is bricked.
9/30/2011 7:42:23 PM • Sony PSP-3000... • Answered on Sep 30, 2011
I cant see any games
They are in the right folder.... but to play these games.. you need to modify the firmware of your psp (if you haven't done so)
8/31/2011 3:42:00 PM • Sony PSP-3000... • Answered on Aug 31, 2011
How to down load games
Hi your psp version needs to modify to run iso format of psp games.. that version was made to run game through UMD only. theres way to make your PSP run iso games >>>> update your OFW (official firmware) to 6.20 version >>>>www.psp-hacks.com using that link you can find there on how to patch the pro-b4 to make your PSP run ISO like standard PSP 2000.
enjoy and learn!!!!! good luck
note: when updating make sure that PSP battery is fully charge and plug it in the charger while updating..
7/9/2011 10:24:47 AM • Sony PSP-3000... • Answered on Jul 09, 2011
How do i turn on
On the side opposite of the power switch, you should find another switch. Move this switch up and it should turn on the WLAN. A green LED will light up on the lower left side of the unit.
7/5/2011 2:42:49 PM • Sony PSP-3000... • Answered on Jul 05, 2011
Last night I played psp
connect the psp to the charger and while on the charger remove the battery and try to turn it on.
5/15/2011 5:23:16 PM • Sony PSP-3000... • Answered on May 15, 2011
How to fix my psp because if im gonna start my
What is the exact problem with the console?
5/7/2011 12:53:29 PM • Sony PSP-3000... • Answered on May 07, 2011
I cannot download my psp
pspisoz.com has iso downloads for backup purposes, but they won't play if you don't have custom firmware installed on your psp
5/5/2011 12:48:20 AM • Sony PSP-3000... • Answered on May 05, 2011
How to downgrade 6.37 to 5.03
:( You cant downgrade. You can only update. 8(
4/13/2011 3:22:44 AM • Sony PSP-3000... • Answered on Apr 13, 2011
I cant download games they said
You need to modify your psp, it is possible if your firmware is 6.35 to do it. you can check it in Settings- PSP information.
If it is 6.35 tell me later.
3/6/2011 6:31:39 PM • Sony PSP-3000... • Answered on Mar 06, 2011
The same as his'. my PSP 3000 lit on for 5-10 secs
Here are some great source where will will get any kinds of Gaming Consoles Solution
» Sony Playstation 3 (PS3) Console
» Microsoft Xbox 360 Console
» Nintendo Wii Console
» Sony PlayStation Portable (PSP) ...
» Nintendo DS Lite Console
» Sony PlayStation 2 (PS2) Console
Number of vote for this solution:222
2/16/2011 8:01:23 PM • Sony PSP-3000... • Answered on Feb 16, 2011
From psp connecting to computer
Hi smsrahman60, Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. -->Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's notthis is how you do it: On themain menu, scroll all the way left to the "Settings" menu. Thenselect "System Settings." Then scroll to "Format MemoryStick" and press X. 2. Connect the PSP to your PC with a USBcable. 3. Press the "home" button on thePSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
2/4/2011 12:43:03 AM • Sony PSP-3000... • Answered on Feb 04, 2011
Im having a hard time enabling wam so i can here muisc on my psp
Hi tiffanybutle,
Based on your concern, I suggest trying the following steps:
1. Turn your PSP on.
2. Make sure that your WLAN switch is turned on.
3. Perform a factory reset.
--> To do this, select "Settings", then select "Restore Default Settings". You will not lose any information or data by performing this step.
However, you may need to reset your wallpapers. Set your name, date, time, etc...
4. Power down your PSP then wait 10 seconds, then power it on.
5. Navigate to "Network Settings".
a. Select "Infrastructure Mode"
b. Select "New Connection" Name this connection as you deem appropriate.
c. Navigate to "WLAN Settings" Select "Scan".
d. Your router should now be listed.
e. Navigate to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, then leave the option as "None"
f. If you selected encryption in ROUTER SET-UP, then select the appropriate WEP, or WPA..
g. Navigate to "Address Settings". Select "Easy"
h. Navigate to "Setting List". Verify that your settings are correct.
i. Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X.
j. You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
Hope it helps,
Thank you for using Fixya.
2/4/2011 12:41:49 AM • Sony PSP-3000... • Answered on Feb 04, 2011
Sony PSP-3000 Silver Console Logo
Popular Tags
225 questions posted
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Video Game Consoles & Games
Most Popular Question
psp 3003 version 5 50 download
  • Video Game Consoles & Games
