20 Most Recent THQ The Lawnmower Man Questions & Answers
0answers
0answers
Centura 3.8 HP Tecumseh lawnmower not working w/o starting fluid
main jet blocked needs carby service its worth it
11/26/2013 1:28:28 AM • THQ The... • Answered on Nov 26, 2013
0answers
Please could you tell me where i can get an
http://www.deere.com/servlet/com.deere.u90785.productcatalog.view.servlets.PublicationsSearchServlet?userAction=publicationsSearchResults&entryPoint=other&orderBy=pubType&
tM=FR&searchCriteria=ltr+180&language=english&submit=Search
5/19/2011 5:32:18 PM • THQ The... • Answered on May 19, 2011
Under load the engine sputters and backfires.
I had the same problem; The first 2 years the engine ran fine and then the third year it started backfiring, so I put a new carburetor on my engine and the same thing happened. The real problem was the valves needed adjusted. Yes I know, this is very rare, but it did happen. I decided not to try this adjustment myself and opted for a mower shop to do it. It cost about $50.00 and the engine has been fine ever since.
10/20/2010 8:57:45 PM • THQ The... • Answered on Oct 20, 2010
No spark
try sanding ends of magnito and check the wire from magnito to sparkplug and see if its broke.
9/18/2010 7:07:28 PM • THQ The... • Answered on Sep 18, 2010
0answers
My Toro LX500 Tractor steering is messed up, the
I have just had the same problem.. the steering shaft is held in place only by the deck sheet metal, which has worn & is now too big to hold the shaft in the correct position, funny how a $2 bearing would have prevented this from ruining an otherwise great mower. I'm going to take mine to a mower shop & hopefully they can install a bearing there.
6/10/2010 2:08:35 AM • THQ The... • Answered on Jun 10, 2010
I have a briggs and stratton 21 inch 6.75 rearbag
it sounds like the carby main jet is blocked you real need to take it to a mover shop as It is a tricky think to clean out there are jets on them that are hard to find ,pin hole size
6/9/2010 10:38:38 PM • THQ The... • Answered on Jun 09, 2010
Which way does the blade go on?
Should be in the manuel or type it into google etc.
5/9/2010 10:11:10 PM • THQ The... • Answered on May 09, 2010
I bought a used 2001 john deere riding mower and
Well it could be you jet which is in the carb this sprays the fuel into the System.. But yeh clean you carb or if you want to be lazy like me... Buy a new one they dont go for tht much.. So look around best place to start is ebay..
Cheers
5/9/2010 9:54:15 PM • THQ The... • Answered on May 09, 2010
My 12 hp tecumseh engine will run till it get hot
Hi. Follow the wires from the oil sensor to the On off switcfh. It sounds like you have have a wire that is grounding as the plastic coating get hot. Check the black wire from the electronic ignition tie plug off the module to the oil sensor for signs of chaffing. If the problem persists try disconnection ONE wire from the oil sensor and see if it will start. If it starts then either the engine is low on oil or the oil level sensor is bad.
Thanks for using FixYa.
Kelly
4/10/2010 11:09:26 PM • THQ The... • Answered on Apr 10, 2010
Replaced camshaft in a Briggs and Stratton engine,
Hi and welcome to FixYa. I am Kelly.
First I will list your engine parts manual here:
http://www.briggsandstratton.com/maint_repair/manual_and_more/docmanualdetails.aspx?showpdf=MS5449_LO.pdf
Now lets get your engine going correctly.
This is how to clean the fuel passages in the carb.
Here is what you need to do:
1. Fuel selector off
2. Remove float bowl mounting screws and nut
3. Remove the BRASS Jet / Orifice in the very bottom of the venturi tube inside the pickup tube. (Flat blade screwdriver) Hold the Orifice up to the light. You should see a pinhole. If it is not clear clean the orifice but do not force anything through the hole.
4. Underneath the Orifice there is yet another BRASS tube that you need to remove. (Flat blade screwdriver) Make sure all of the holes in the tube are clear. The tube will be over 2 inches long. Clean it and reinstall it.
5. Reinstall the Orifice.
6. Using a catch fuel container turn on the fuel selector. Fuel should flow at a good rate. GENTLY lift the float assy level and make sure fuel flow shuts off. When you drop the float again fuel should flow.
If you do not have fuel flow at this point the needle and seat will need to be inspected. Fuel selector OFF.
(The following procedure is to be done only if there is no fuel flow with fuel selector on.)
a. Remove the silver float pivot pin retaining screw
b. Drop the Float down (The needle will come off with the float. NOTE the position)
c. Inspect the tapered rubber of the needle If should be pointed. If it is not pointed then the rubber tip is stuck inside the seat.
d. Clean the seat hole ONLY if obstructed. (Easily damaged)
e. FUEL Selector on then off fuel should rapidly flow through the needle seat.
f. Renistall Float and needle making sure to get the pivot / hinge pin installed correctly and reinstall the silver retaining screw.
g. Fuel selector ON. Raise and lower float checking for free movement and fuel flow.
7. If there still is no fuel flow at this point remove the fuel hose from the carb and check fuel flow. If no flow check that gas tank exit hole, fuel filter (if installed) and the selector valve assy for obstructions. Reassemble connections.
FUEL FLOW IS GOOD
8. BEFORE you install the float bowl inspect the bowl nut. There are 2 holes in the side of the nut where it screws in to the bottom of the carb that must be clear.
9. Install Float bowl mounting screws and nut. Check for leaks.
10. Test engine.
That should do it. (carb cleaning 101)
Kelly
4/10/2010 11:04:34 PM • THQ The... • Answered on Apr 10, 2010
Does anyone on this planet know for sure the type
google it
4/5/2010 5:53:07 PM • THQ The... • Answered on Apr 05, 2010
THQ The Lawnmower Man Logo
58 questions posted
Top THQ Video Game Consoles & Games Experts
ZJ Limited
ZJ Limited
MegaByteMe
MegaByteMe
Mark Ultra
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • THQ Video Game Consoles & Games
Most Popular Question
toro lx500 tractor steering messed up
  • Video Game Consoles & Games
