20 Most Recent Haier 20.5 cu. ft. / 580 liter Upright Freezer HUF138PA Questions & Answers
HAIRE FREEZER IS BUZZING
CALL Chas&Son,s at 570-379-0993 and they will come out the same day no less okay
2/12/2013 6:01:37 PM • Haier 20.5 cu.... • Answered on Feb 12, 2013
Freezer has stopped freezing
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
2/26/2011 10:12:39 PM • Haier 20.5 cu.... • Answered on Feb 26, 2011
Just noticed about 3 days ago ice build up below
sound like the defrost drain line is blocked
2/24/2011 5:06:30 PM • Haier 20.5 cu.... • Answered on Feb 24, 2011
Buzzer is going off and the door wont close and
The air leaks through the door making the things melting inside. Please fix the immediately. Usually the problem is on door seal or hinges .
1/10/2011 11:34:45 AM • Haier 20.5 cu.... • Answered on Jan 10, 2011
I recently bought a 20.5
no sounds like the door is not sealing
9/14/2010 3:52:04 AM • Haier 20.5 cu.... • Answered on Sep 14, 2010
Haier HUF138PA-Freezer not freezing
just bought one that a repair man had already been through with similar issues. i wanted it as a fridge so this was no problem. took me about 5 minutes to figure out the reason it wasn't freezing though...the switch at the top that turns the light on when you open it also turns on the fan when you close the door. the door however sits just a tad too low to fully engage the switch. put a piece of tape over the switch and let it cool for 24 hours. chances are this will solve your problem!
1/20/2009 3:53:26 PM • Haier 20.5 cu.... • Answered on Jan 20, 2009
Humming
A hum followed by a click sound is an indication of a failure at the compressor. Possibly the compressor motor has gone into a locked rotor condition. A locked rotor condition can be checked using an ammeter. The name plate on the compressor will have a rating after LRA. If the ammeter reading is equal to the LRA rating the compressor is done. If it is a reading of about 80% of the LRA (locked rotor amperage) it is possible that a relay or capacitor has failed which is replaceable.
9/5/2008 2:00:44 PM • Haier 20.5 cu.... • Answered on Sep 05, 2008
2answers
Installation manual for walk in freezer
you search on net.
4/30/2021 2:53:27 PM • Haier Freezers • Answered on Apr 30, 2021
What does Ed mean on a haier freezer and how do I get rid of it
You can try resetting it by unplugging it for 10 minutes.
The Ed error code is referring to the defrost heating system.
10/28/2019 11:50:26 PM • Haier Freezers • Answered on Oct 28, 2019
How to stop the alarm going off on an upright Haier freezer.
https://www.haierappliances.com/support/freezers/troubleshooting try this web site for direct answers from the manufacturer.
5/29/2019 1:43:04 AM • Haier Freezers • Answered on May 29, 2019
Haier chest freezer doesn't cool, indicator lights don't come on, doesn't make noise when plugged in, could the indicator lights stop it from working?
If compressor isn’t running, it’s either a thermostat / control board problem, or a power supply problem.
1/30/2019 6:44:34 PM • Haier Freezers • Answered on Jan 30, 2019
My haier freezer will not start, power button is on but run button is not on
If compressor isn’t running, it’s probably a thermostat problem
10/11/2018 1:37:57 PM • Haier Freezers • Answered on Oct 11, 2018
How do I get manual for Haier freezer?
https://www.manualslib.com/brand/haier/freezer.html Identify the model and free manuals online at the link shown. Haier Freezer manuals
5/24/2018 9:57:05 PM • Haier Freezers • Answered on May 24, 2018
Haier 20.5 cu. ft. / 580 liter Upright Freezer HUF138PA Logo
16 questions posted
Top Haier Freezers Experts
NOEL
NOEL
Rob Hill
Rob Hill
Are you a Haier Freezer Expert? Answer questions, earn points and help others
View Most Popular
Haier Freezers
  • Haier Freezers
Most Popular Question
just noticed about 3 days ago ice build
  • Freezers
