20 Most Recent
Haier 24 in. ESD100 Built-in Dishwasher Questions & Answers
Hi threr
I have the following
This is either a fault with the temperature sensors or the timer it's self, Not a simple one to diagnose without some general knowledge of how these circuits operate
Will not complete wash cycle
I had a similar problem, except I did not notice a burning smell. I would put my dishwasher on and it would stay on the wash cylce for ever. I had to manually turn the dial to the next cycle.
I had a repairman in and told him I thought it may be the thermostat (from everything I had read online). He dismissd my diagnosis and said it was the timer. He order the timer and came back 2 weeks later and replaced it. It did not solve the problem. He then ordered the thermostats (my Haier ESD102 has 2 of them) and came back 3 weeks later and installed them. That solved the problem!
Timer = $137 CAD (covered by warranty)
Thermostat 1 = $14 CAD
Thermostat 2 = $21 CAD
Haier dishwasher XIB6B2S3FS-80 cycle not ending
First thing to try is a reset..
Unplug or turn it off at the breaker for 5 minutes.
You can also try this but it's used to clear error codes....
Simultaneously press and hold Cycle Select and Start pads for 5 seconds.
Press ANY button to complete the reset process. ...
The unit will now be ready to use/function normally at this time.
4/11/2023 2:43:19 PM •
Haier...
Answered
on Apr 11, 2023
Haier appliances repair parts search
With 30,000 9.4 out 10 reviews, they must be good!
It won't be the element though, it will the thermistor or the thermostat that is failing. Some can be calibrated. It may also be a failed circulation fan on a fan assisted oven.
Test the oven first with an oven thermometer. elements can be tested for resistance, but in my experience they work or they don't, they don't half work.
https://fixpart.de/de/uber-uns
3/11/2023 7:33:05 PM •
Haier...
Answered
on Mar 11, 2023
Haier dw9-tfe3 series dishwasher fault
Hi
I got the E6 error at the end of cycle and inside it was exceptionally hot and dry, no leak under DW,
I put breaker off and error was persistent, it finally disappeared after a moment, I guess after temperature went down.
If it happens again I'll update the topic.
7/15/2022 1:49:00 PM •
Haier...
Answered
on Jul 15, 2022
