20 Most Recent
Ebel E Type 9157C11/5716 Wrist Watch Questions & Answers
Removing pins from men's 1911 Ebel wrist band
Punch must be metal. Size of punch must be the same as the screw size. Punch must go into the hollow part left by the screw, so, when tapped, the screw end (nut) will come out from the opposite side to where screw came out. Start tapping lightly and go harder and harder till you see the ends coming out. Read my tip - it can help as well. Tools can be bought on Ebay.
Rate me, plz.
Having trouble removing pin from men's Ebel 1911
Watchmakers are using special pin removing tools and punches. You can find them on Ebay. If you have pins you can not damage threads as pins do not have any threads - they are friction fitted. Punch must be the size of the pin end you can see. Some pins come out easily, some quite hard, so, use appropriate strength to drive pins out. In case if there are screws - use small screwdriver to fit in the slotted screw end and unscrew the screw.
Rate me, plz.
Change men's ebel watch battery
This is for a woman's watch but may apply to yours. You need to remove the screws around the bezel of the front of the watch (not accessed through the rear like most watches).Be sure to use the correct size screwdriver to avoid marring the screws. Then you will need to remove the half of the split stem attached to the crown. Remove the movement from the front, replace the cell, lube the gaskets, and reassemble.This has been asked before. Here is that answer:www.fixya.com/support/t1684765-ebel_wave_ladies_watch_battery
3/26/2017 5:28:53 PM •
Ebel Watches
Answered
on Mar 26, 2017
Have an Ebel Men's Watch:
The really nice thing about your watch is that when you need a battery, the watch gives you a 30 day notice by having the second hand do what I call " a triple step" where the watch keeps time, but youe second hand goes 3-4 steps real fast and then stops. Please take your watch to a reputable watch repairman, because your watch has a Cartier movement , and NOBODY but Cartier has the parts for your watch if somebody who dosn.t know what they are doing messes it up. If you have anymore problems feel free to ask me anytime . I LOVE EBELS!!!!
11/2/2011 2:37:15 PM •
Ebel Watches
Answered
on Nov 02, 2011
My crystal cracked a couple
the crystal is not properly attached it may have tiny opening where moisture goes inside. you have to bring it to watch service center immediately to avoid much bigger problem. i hope i had been helped you.
9/6/2011 4:20:21 PM •
Ebel Watches
Answered
on Sep 06, 2011
I have a Versace (Madison)
You can only get the push button only in the Ebel swiss service centre.You cant buy it online.Since it is very costly watch you have to buy the original parts in their service centre.
Contact them ask for your local service centre address.
http://www.ebel.com/#/en/contact-us
Store locator in your area:
http://www.ebel.com/#/en/Store-locator
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
9/11/2010 3:19:19 AM •
Ebel Watches
Answered
on Sep 11, 2010
