20 Most Recent
Leapster Electronic Book: Junie B. Jones Journal Questions & Answers
How do you delete existing profile in Junie B Jones Leapster game
To delete a player profile, go to the player profile screen and press
and continue to hold down the following buttons in sequence:
Home
A button
Left arrow
Then, touch the X icon that appears at the bottom of the screen and follow audio instructions.
Note: You can only delete a name when all three name slots are filled.
The above procedure only works on LEAPSTER 2.
Directly from Leapster website -
Question
How do I delete or change a player name on Leapster™ cartridges?
Answer
It is possible to remove a player once you have added three player names to the cartridge. If there is a name on the cartridge that you want to remove, take these steps.
1- Add new players until there are three players on the cartridge.
2- Once you have three players on the cartridge, an "X" will appear below each player's name.
3- Touch the "X", then touch the name of the player you want to delete. Touch "Yes" to delete the name. Then add a new name, or touch OK twice to go back to the sign-in screen without adding a name. Two names will always remain on the cartridge.
This is a design flaw with leapsters games (apparently nobody thought to think that they do get sold secondhand or passed down in families)
Since you havent specified the system -
LEAPSTER ORIGINAL
LEAPSTER 2
LEAPSTER LMAX
Clicking on any of the above will get you the owners manuals in PDF format.
Thanks for using FixYa - if you need more clarification on your question, please reply to me first.
Thank you.
6/5/2013 6:14:50 PM •
Leapster...
Answered
on Jun 05, 2013
Hi....
To delete a player profile, go to the player profile screen and press and continue to hold down the following buttons in sequence:
Home
A button
Left arrow
11/19/2009 12:36:04 AM •
Leapster...
Answered
on Nov 19, 2009
My 3 week old leapster
Hello.
I understand your frustration. Try removing the batteries and then put them back again and see if that will fix your problem. If it doesn't fix it, return it back where you bought it and ask for a replacement.
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
When the game turns on
Pokemon crystal is a Game boy color game, there for it will not run the original Game boy.
What are some good catering services?
I recomenr you Alchemiq, it is a quality caterers https://alchemiq.com/catering-nyc/. They offer gourmet appetizers, fancy food stations, upscale cocktail catering, and event design
Recommended System Requirements
Find out if you can run that game on your PC Learn about. System Requirements Lab
www.systemrequirementslab.com
you can find here the minimum and required system requirements for most of the games and the updates needed for you to download to make the games run on your system.
Update profile
Clear your question, because which types of profile update. Then i better answer given.
Thanks.
Well i got the new
Unfortunately, your Logitech controller uses the DirectInput control standard, and Deathly Hollows Part 1 will only work with the new XInput standard introduced in Windows 7. The only Xinput controller so far is a 360 controller hooked into the PC. There are also some software emulation solutions, but those can be a bit tricky and buggy to use. For the best experience, I'd recommend purchasing a 360 pad and the corresponding wireless sensor.
How to download project igi pc game
Hi, you can download Project IGI game from torrents for free from the below link:
http://thepiratebay.org/torrent/3373055
In order to download torrents mentioned above you need to download and install the Utorrent Bittorrent client from the below link:
http://www.utorrent.com/
Please install Utorrent and then open the torrent file mentioned above to download Project IGI.
