20 Most Recent Haier HTQ21JABWW Top Freezer Refrigerator Questions & Answers
I have a haier model # htq18jabww-01 and the freezer seems to b working fine but the fridge does not seem to be cold at all...any soultions??
The "Cold-to-Coldest" adjuster in the freezer steals chilled air from the refrigerator to add more to the freezer. It's a mechanical damper. Set it fully CCW to cold (warmest position). I also put duck tape over half the chilled air outlets in the freezer to increase the chilled air pressure feeding the refrigerator section. Set the thermostat in the refrigerator to 8 or 9 and the freezer works fine and everything in the refrigerator is 38F.
4/24/2017 12:21:19 AM • Haier HTQ21JABWW... • Answered on Apr 24, 2017
We noticed that the freezer was not freezing well
Hello there,When your refrigerator starts building up ice at the back of the refrigerator and is not getting cold, the problem actually is caused by defrost settings of the refrigerator.The defrost settings is composed of the defrost thermostat, defrost heater and the defrost timer. If any of the three should go bad, then the refrigerator would begin to build up ice and not cool.You will have to test the defrost thermostat, heater and timer. Mostly the problem used to be the defrost thermostat.Once you check the three and see that they are okay, then you need to refill the gas cylinder with refrigerant.Clean the condenser coil, refill refrigerant and test the thermostat, heater and timer.That would get your refrigerator up and running.All the best.Elect_Comp
11/1/2011 8:15:34 PM • Haier HTQ21JABWW... • Answered on Nov 01, 2011
I need a schematic for a haier htq21jaaww
I have a copy of HTQ21AAWW Service manual that include the following :
eatures, product code explanation and series introduction, specification, safety precaution, parts and functions, function schedule, system flow chart, circuit diagram, maintenance service and troubleshooting, troubleshooting and repairs.
If you want to download the copy, I'm online now at the pay question. Click here.
Jdvillanueva
10/3/2011 2:04:24 AM • Haier HTQ21JABWW... • Answered on Oct 03, 2011
Both refrigerator vents had frost and we defrosted
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/6/2011 3:10:30 AM • Haier HTQ21JABWW... • Answered on Sep 06, 2011
Freezer is cold but the fridge is not.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
6/4/2011 3:02:18 AM • Haier HTQ21JABWW... • Answered on Jun 04, 2011
I need the fan that is on the freezer
You can get it at Johnstone Supply or similar store for less than $20. You will only get the motor, don't throw away the fan blades.
good luck
3/7/2010 6:47:29 PM • Haier HTQ21JABWW... • Answered on Mar 07, 2010
Fridge not cold but freezer working great
I had the same problem, and it turned out to be a cooked fan motor.
I couldn't find a reasonable (less than $150) replacement motor from Haier places, but I just took the motor out and took it to an appliance repair center (in North Denver)
They said it was a standard part, charged me around $22 for a new one and I was all set.
For my replacement motor, it was a reversible design, and was initially set to go the wrong way, so I had to reverse it.
4/22/2009 10:33:23 PM • Haier HTQ21JABWW... • Answered on Apr 22, 2009
Cold freezer-motor burned up
I had the same issue, but without the burnt parts.
4/22/2009 10:32:25 PM • Haier HTQ21JABWW... • Answered on Apr 22, 2009
Haier Fridge and Freezer
The compressor and Freon are all one sealed unit,never heard of a separated system. by turning it on you will just drain the rest of the freon.
2/16/2009 3:08:37 AM • Haier HTQ21JABWW... • Answered on Feb 16, 2009
2answers
Haier model# HTQ21J*SS freezer ices up with melted water, not draining
Go to an electronics section of Walmart or Target, buy a can of "CleanSafe Dust Remover" compressed air in a can and try to blow the drain clear from the freezer portion. If that doeasn't work, let me know.
2/10/2009 5:54:23 AM • Haier HTQ21JABWW... • Answered on Feb 10, 2009
Freezer at 10 deg, fridge at 50
haier refrigerators have been known to have the cold control go bad. it only sense's the temp in the fresh food section so that would be why the freezer is still ok. The problem is the control is cutting out to fast and not letting the temp go lower. from what you said i would take that there is good air flow between the freezer and the fresh food compartment. so the only thing it could be is the cold control. I would replace it and you should be all set.
11/10/2008 2:48:46 PM • Haier HTQ21JABWW... • Answered on Nov 10, 2008
Freezer fan is not working
the fan may be jammed due to ice build up. in the first instance i would give the unit a full defrost for 48 hours then see if the fan starts after, if not the fan motor may be u/s.
6/2/2007 1:55:08 PM • Haier HTQ21JABWW... • Answered on Jun 02, 2007
Haier model HVF042ABL freezing temperatures and wine bottles exploding.
Steve, Have checked around the web for parts..ie temp sensor, control board, which would cause your problem if defective, and there are no parts avalible. NUTS!
2/27/2023 4:31:11 PM • Haier... • Answered on Feb 27, 2023
Fan Not Coming On & Compressor Is Hot
Ckecked around for the fan, parts for this unit are few and far between did locate some on ebay so head over there. Cuz there were quite a few but without seeing yours I couldn't match up what I was seeing.
1/22/2023 3:49:52 PM • Haier... • Answered on Jan 22, 2023
Haier HTQ21JABWW Top Freezer Refrigerator Logo
28 questions posted
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Haier Refrigerators
  • Haier Refrigerators
Most Popular Question
freezer 10 deg fridge 50
  • Refrigerators
