20 Most Recent
Nokia 5310 Unlocked Cell Phone with 2 MP Camera MP3 Video Player Questions & Answers
How to unlock security keyguard on nokia 5310 ???
I work for Nokia and i can help you this will only work for Nokia 5310 what you do is the following
Step 1 : Type in : 11111
Step 2: Type in: 22222
Step 3: Type in: 33333
Step 4: Type in 44444
Step 5: Type in: 55555
Step 6: Type in: 66666
Step 7: Type in: 77777
Step 8: Type in: 88888
Step 9: Type in: 99999
Step 10: Type in: 00000
Step 11: Take battery out wait a good 10 minutes as this resets the code
turn your phone on and repeat the same process above in the same order and wait 10 more minutes and the turn it on it will ask for your security code as you have followed the steps the code will now be to the default of: 12345 then enter your new code and the verify it by entering the new code you just entered and away you go thanks.
Daniel Carter
Nokia Support
Data recovery software
There is no Data Recovery SW for phones yet. Once you lose data you lose data for good. The only solution is to backup data and settings on a regular basis.
N82 keypad
What about the key pad? Is it malfunctioning? If yes then may be that some fine dust may have got collected between the keys and the buttons. So, remove the front of the phone, lift the rubber pad and clean the buttons with a soft cloth and the clean the rubber pad as well and re-assemble. If any key is bad then it should be replaced by a trained technician, preferably from Nokia Care.
Puk code of nokia 5310
PUK stands for Personal Unblocking Key. This is a unique eight-digit code specific to your SIM card. This is required when the PIN number to unlock your mobile phone is entered incorrectly 3 times. You are then given 10 attempts to enter your PUK code. If an incorrect PUK code is entered after the 10th attempt, you will block your SIM card permanently and will require a new SIM card from your mobile phone provider. PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack. If you do not have this then - Please contact your phone service provider. Your cell phone service provider can give you the PUK code once you give them your account details and they have confirmed your identity. For details to obtain the PUK code for the SIM card, please click on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
