20 Most Recent Haier HTE18WAA Top Freezer Refrigerator Questions & Answers
Any bathroom wet sealer will do the job
Haier HTE18WAA... | Answered on Oct 03, 2014
I suggest that you remove the bottom layer of the freezer - you'll see its just a piece of plastic to allow cold air to circulate underneath. There is a metal tray in the back of the freezer there that has a drain in it - I'll bet its frozen solid and the condensation from the defrost cycles are dripping down into the fridge part.
Haier HTE18WAA... | Answered on Feb 27, 2013
my refridgerator freezes too much in the freezer and does not get cool in the cooling section
Haier HTE18WAA... | Answered on Jul 13, 2011
Sorry to read about your problem, I hope this helps you out.
the freezer adjustment, is in the refrigerator at the top
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Haier HTE18WAA... | Answered on Jan 05, 2011
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Haier HTE18WAA... | Answered on Dec 27, 2010
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
rty356
Haier HTE18WAA... | Answered on Sep 29, 2010
Several things could cause the problem depending on the model. First, the defrost heater could be bad. It can be checked with a continuity tester or an ohm meter. Second, the defrost timer could be bad and may not be advancing. If you manually advance the defrost timer till it is in the defrost mode, and the defrost heater does heat up, that usually indicates that the heater is good but the timer is bad. Third, there is also a defrost thermostat attached to the heater. It may be bad. The defrost thermostat is a N/C (normally closed) switch and can be checked with a continuity tester.
The heater and thermostat are in the area of the cooling coils, and the timer is many times under the refrigerator.
Hope that helps.
Haier HTE18WAA... | Answered on Jun 24, 2010
I would agree that this is a thermostat issue. I would also clean the condenser coils.
Haier HTE18WAA... | Answered on Jun 16, 2010
if you go to marcone.com with your model # it will givw you a full parts breakdown and allow you to buy the mising parts
Haier HTE18WAA... | Answered on Jun 10, 2010
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Haier HTE18WAA... | Answered on May 24, 2010
Haier HTE18WAA Top Freezer Refrigerator Logo
59 questions posted
Top Haier Refrigerators Experts
geob91
Marvin
Marvin
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Haier Refrigerators
  • Haier Refrigerators
Most Popular Question
our hotpoint fridge ran continuously
  • Refrigerators
