20 Most Recent
Microsoft Headset for Xbox 360 Questions & Answers
I can hear trough my headset but not talk
okay, this is obvious but first of all make sure this switch on your headset is not on mute. If alls good there go to your dashboard settings and you should see communication and make sure none of these are blocked. If this also isn't the problem it looks like you are going to need a new headset. It should have a years warrenty if that helps?
4/15/2013 8:44:14 PM •
Microsoft...
Answered
on Apr 15, 2013
Broken plug
you will not be able to do this due to the different set ups of the headsets
12/20/2012 11:55:54 PM •
Microsoft...
Answered
on Dec 20, 2012
I cant hear on my
This is a problem with the connection port or wire connecting the mic. You need to get the mic replaced.
7/29/2012 12:35:53 AM •
Microsoft...
Answered
on Jul 29, 2012
Every time i talk on
THE PROBLEN IS WITH YOUR MIC... I WOULD CONTACT MICROSOFT ABOUT THIS THEY WILL HAVE THE ANSWER. I HAVE FOUND THAT THE MICROSOFT HEAD SETS THAT COME WITH THE X BOX 360 ARE A PIECE OF JUNK AND DO NOT LAST LONG. I WOULD RECOMMED THAT YOU GET THE HORI X2 TURBO CONTROLLER. IT WILL DO EVERYTHING THAT THE FACTORY UNIT WILL DO PLUS YOU HAVE THE TURBO FUNCTION SPEED CONTROL AND MUCH MORE...
7/10/2011 5:18:34 PM •
Microsoft...
Answered
on Jul 10, 2011
I just got the motorola
do you have the switch on the cable turned up so you can hear? you need to contact microsoft for the answer to a specifc question they have tech. support that has the knowledge to take care of any issues you might have.
7/10/2011 5:10:36 PM •
Microsoft...
Answered
on Jul 10, 2011
Ive bought a new headset
I am confused by your question. It is unclear if you are talking about trying another headset or another x box 360 unit. You said "another sbox and it works fine......" Also are you taking about a wired or wireless headset? Please advise and I will get back to you.
best.
7/4/2011 9:26:30 PM •
Microsoft...
Answered
on Jul 04, 2011
When i plug in my
You used the term "plug in my mic". I assume you mean the microsoft mic and head set. one of the best ways to check the headset and mic. is to go onto microsoft live and attempt to leave someonw a voice message. during the message you will get a message that says your mic is not working. also after you finish the voice message attempt to play if back if you do not hear anything then the problem is with your microsoft head set and attached mic. if new take if back to exchange for another one. there could possibly be something wrong with the port connection on you microsoft controller.
7/1/2011 3:42:14 PM •
Microsoft...
Answered
on Jul 01, 2011
I cannot hear my freinds
there should be a switch on the headphones or in the game settings that allow you to hear what is being said. I hope that this is the right thing that im suggesting and that its helpful.
7/1/2011 4:59:25 AM •
Microsoft...
Answered
on Jul 01, 2011
Ok well im trying to
the solution for this is in system settings on your 360... there are game audio options in there
1: select send audio to headset
2: select "confirm selection"
3: restart system
4: enjoy
4/2/2011 7:15:30 PM •
Microsoft...
Answered
on Apr 02, 2011
I can talk to other people but they can hear me
Sorry dude, but it's really sounding like you got a bad headset on your hands. I'd test it on another controller, and if it still happens, then its definitely the headset. If so, just call Microsoft with your serial number and tell them what happened and they will replace it for FREE! The number for their customer support is (800) 469-9269. I've used it many times, and they've replaced 2 of my broken controllers! Good luck!
3/8/2011 7:05:03 PM •
Microsoft...
Answered
on Mar 08, 2011
Can't hear through my xbox
In the settings menu for under Xbox dash board, there is a place to select how you want to listen, either through the stereo or TV speakers or through the headset. There is also a selection for headsset/stereo..
2/8/2011 12:35:12 AM •
Microsoft...
Answered
on Feb 08, 2011
I can speak though my
problem un-fixable you need to buy a new head set this is a problem with were the head set connects to the cord and its messed up in the head set sorry
2/1/2011 3:43:15 AM •
Microsoft...
Answered
on Feb 01, 2011
My friends can hear me through xbox live party
Theres is a loose wire in your headset most likely. Try plugging it into another controller just to be sure its not the controller. If there is a loose wire there is not much you can do other than buy a new headset.
11/21/2010 2:39:06 AM •
Microsoft...
Answered
on Nov 21, 2010
When i speak though the
I have a headset with the same problem. It is due to a loose connection in the headset. However you may want to plug in another headset to the controller just to be sure its not the controller.
11/20/2010 12:50:32 AM •
Microsoft...
Answered
on Nov 20, 2010
I can't hear my friends but they can hear me on my xbox headset
It sounds like your headset is worn out. We are constantly replaceing them at my house. The little wires inside the cord where they go into the plug end tend to break and fail to give good/reliable conection.
You can try cleaning the plug end and checking that the receptical in the controler is free of debris, if that works great, if not buy a new headset.
Good luck
9/22/2010 12:26:21 AM •
Microsoft...
Answered
on Sep 22, 2010
