20 Most Recent
THQ Saints Row for Xbox 360 Questions & Answers
My game is scrached.
Did this occur by moving the console while the game is running?
If so then you have ringed your disc and it is unplayable.
I have the same thing
check and see if there are straches on the bottom of the disk and try cleaning it if theres a large ring on the bottom of your disk than it wont work
SAINTS ROW ON XBOX 360 Freezes on loading screen
It might be a corrupt game disc and you'll need to return it and get a new copy. If that's not it try to see if you can upload it to your hard drive. If that doesn't work then you might have to consider formating your hard drive because it might have corruption on that drive. If you are going to try to format, then by all means get a memory unit to transfer data to a new hard drive preferrable.
Hope this helps.
Sincerely, CBR2009
Saints Row for 360 stuck on Loading Screen plz help
You may have an issue either with the game or your display. We have some steps you can try in the below article, but you may want to contact the publisher to look into the issue further.
Also, have you all tried cleaning your game disk or exchanging the disk at the retail store for another copy? Do you receive an error message, does the console fully lockup, or does the action on screen slow down but the game still plays?
Here are some support sites you might want to check out..
http://support.microsoft.com/kb/911151/en-us
http://support.microsoft.com/kb/907586/en-us
I have a problem with
You have to upgrade your VGA card most probably but anyway you can try the following:
Install the latest VGA drivers from Intel website which can improve performance
Install DX 9.0c to remove some glitches/bugs
The amount of graphic processing is below par for your built-in graphic card when it is unable to draw objects in real time at FPS rate of 30 or above.
Let me know if the above steps help to improve the performance of the game or not.
Playstation controller pc
ePSXe is your friend here. Emuzone is where you need to go, or just google it.
Please keep in mind that these emulators, while they may work with disk images, legally requires that you physically own the game you are trying to play.
Also having a 2 stick joypad in your computer helps in the controller configuration.
Hope that helps.
Cheers from New Zealand :D
