20 Most Recent
Square Enix Final Fantasy XI for Xbox 360 Questions & Answers
When trying to install the
There is a couple of things that you can try here first off.
The condition of the disk if there is any scratches on it please get it repaired from a video game store or a movie store.
If you have a weak or slow internet connection you may need to borrow a buddies connection.
If it is not installing it on your hard drive then try it out on another machine to see if it is the game or the machine.
if the game is the issue then get it repaired or replaced.
if the system is the issue then the laser lens may need to be cleaned or replaced
Put in disk in 360. Play Playonline viewer, but
I had this problem recently. What happened was you closed the game without logging out of Playonline. The long shut down I call it. This corrupts the FFXI data on your HDD. And since FFXI does not appear in the memory you have to format your HDD and redownload. I can guarantee if you put the disc in your xbox with no HDD that it will read or even place it in an xbox with a HDD that has never had FFXI.
I spent 5 hrs. downloading
There are many others facing this same problem.
You can try this procedure as the game is actually loaded in your hdd ,the disk is unreadable but the game is there on the hdd.
Don't perform format or reformatting option after you get this problem.
If you have done the formatting/reformatting then the game is wiped from the hdd.
1) Remove the HDD from the console and boot the console up with FFXI in the tray and attempt to boot the game. You will get an error about how the game can't start without an Internet connection. Go back to dashboard. Turn off the console.
2) Take the HDD with the FFXI data and the game disc and put them on another console. Attempt to boot up FFXI and you should get to a PlayOnline screen that mentions your data became corrupted due to an improper shutdown. When you attempt to launch PlayOnline Viewer, you will get an error saying the game could not be started and be punted back to dashboard. Turn off the console.
3) Take the HDD with the FFXI data and the game disc and put them on your original console. Boot the game. It should boot up with the same error on the other console, mentioning the possibility of corrupt data due to improper shutdown. However, this time when you launch PlayOnline Viewer, it should work and take you into the game.
If it does not work for the first time.Try the procedure 3-4 times.it will work.It has helped some of the users.
Thanks. keep updated for any more query.you can rate this solution
and show your appreciation.
I bought FF11 the other night installed it and sat
I am so sorry that more people are going through this. You MUST LOG OUT OF PLAYONLINE before you can close the game. This long process is needed. Since you did not log out of play online and exit to the dashboard their way your data is now corrupted. FFXI does not appear in the HDD memory and you have to format the HDD and redownload all over again.
Ff 11 game crashes at character login
for some reason your xbox is taking a long time to connect to the Square Enix servers. I can only suggest you make sure to have your cache cleared for a smooth load. You may have to redownload the game.
When requested to install told that not enough
It may need additional temporary space. Now you say youhave 32 GB and it requires 39 GB. That's 39 GB- 4 GB= 35leaving a 3 GB play room. Too close for comfort. Eliminatethose videos of the dog and cat playing, and you'll have tonsof space.
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
