20 Most Recent
Stanley Tools Tlm 100 Fatmax Tru - Laser Distance Measurer - 77 - 910 Questions & Answers
A rectangular park is 115 m by 95 m.At least how
This is, of course, a trick question. The simple answer is 12, because the circumference of the park is 420m and 12 x 420m is 5040m. However, we are not told how close to the edge the runner is able to run, nor whether he (or she) rounds off the corners. If, for example, the park is bounded by a fence, the runner may have to run 1m inside the fence and will almost certainly not run completely in to each corner. Adjusting for these factors could reduce the distance run per lap to 410m or less, in which case an additional lap will be necessary. In fact, if the actual distance run is less than 416.67m per lap, then 13 laps must be run.
How to calibrate stanley 400mm digital level
Select a location that is relatively level and flat.
The edge of a bench is best so that the level can be placed in the same position when the level is rotated during the calibration process.
To calibrate follow below:
Press and hold Calibrate button for about 4 seconds. The display will now show CAL1.
Press the Calibrate button briefly again and the 1 will flash, a beep will be heard and CAL2 will be displayed.
Rotate the level 180° end to end with the display still facing you whilst the level is now upside down. Place the level in the same location.
Press the Calibrate button briefly one last time. The 2 will flash, a beep will be heard and the display will revert back to normal.
4/21/2022 10:02:27 PM •
Stanley...
Answered
on Apr 21, 2022
How to repair a Stanley powerlock 16 measuring tape ?
From the the attached photo I see that you have completely disassemble the tape. This makes the tape almost impossible to reassemble. The spring has to be back wound fully, the blade attached and retracted back into the case using the back wound spring. This requires special equipment that is not overly complicated, however not possible to make for a once off use. I have designed, built and trained operators to use this type of equipment in a production situation, however in my 35 years of experience I have never been seen anyone back wind a spring by hand. Sorry to say but the tape is ready for the trash.
7/20/2021 5:49:35 AM •
Stanley...
Answered
on Jul 20, 2021
My wife bought me Xmas 2018 a Stanley Fatmax Lithium ion LED Spotlight FL5W10 600 lumens. The bright portion of the LED has quit working. What are my options - has only been 3 months.
here is the website:
https://www.stanleytools.com/products/hand-tools/flashlights-lighting/spotlight/waterproof-led-rechargeable-spotlight/fl5w10and they say the warranty is 1 year:Warranty1 Year Limited WarrantyThe manufacturer, Baccus Global warrants products against defects in materials and workmanship for a period of ONE (1) YEAR from the date of retail purchase by the original end-user purchaser ("Warranty Period").If there is a defect and a valid claim is received within the Warranty Period, the defective product can be replaced or repaired in the following ways: (1) Return the product to the manufacturer for repair or replacement at manufacturer's option. Proof of purchase may be required by manufacturer. (2) Return the product to the retailer where product was purchased for an exchange (provided that the store is a participating retailer). Returns to retailer should be made within the time period of the retailer's return policy for exchanges only (usually 30 to 90 days after the sale). Proof of purchase may be required. Please check with the retailer for their specific return policy regarding returns that are beyond the time set for exchanges. Please call 1-877-571-2391 for more information or return instructions.This warranty does not apply to accessories, bulbs, fuses and batteries; defects resulting from normal wear and tear, accidents; damages sustained during shipping; alterations; unauthorized use or repair; neglect, misuse, abuse; and failure to follow instructions for care and maintenance for the product.OOtherwise, check with the seller who sold it to your wife - If they are unwilling, and more companies seem to be going this route, go to the Manufacturer
3/4/2019 7:48:06 PM •
Stanley...
Answered
on Mar 04, 2019
