20 Most Recent
Velodyne DPS-10 Subwoofer Questions & Answers
My Velodyne DPS-10 subwoofer hums when you plug in
hi,
You have to check the RCA cable to the sub woofer. The RCA cabe have two connections inside it, one is for gain and the other is for ground sheild. If the ground sheild is broken then there will be hum from the sub woofer and it will increase if you touch the ground (rear metal pannel is connected to the ground). Replace the cable and check it again.
ok
Works great for a period
it sounds like a bad sub woofer amplifer, as the unit heats up the capacitors start to leak and the amp will try to shut down. it would depend on how hard you are driving it, (heavy bass versus light bass) that would cause it to fail sooner than later. You need to replace the internal amp
Subwoofer DPS-10 == works great
I also had the same problem, I bought final scratch used with 2 ground loop isolators, even with those I still had the buzz. After buying the
3-to-2 prong 110 volt plug everything is perfect
I got mine and homedepot
Wont power up dts10
I'm having an issue with my Velo DLS5000R. I pulled the amplifier,and inside the plate, where the power cord goes in, is a small 8amp glass-tube-type fuse. You might try checking for one on your sub.
Humming sound when on/off
humming sound when on is usual if the volume is turned up.
humming sound the same when on or off could be transformer plates fluxing.
if loud recommend replacement of power supply.
if ok then recommend unplugging the device after use.
