20 Most Recent Yardworks Hand Spreader Questions & Answers
https://www.walbro.com/wp-content/uploads/2016/01/WTseries.pdf
wt-vpcwsvyyc3pdlgp2ljaea1vq-1-0_0.png You may or may not need to remove adjustment limiter caps and requires specialty adjustment tool (spline, D, DD, pacman, etc. See Ebay/Amazon ~$10 for mixed set)
Garden | Answered 18 minutes ago
Next time you are at Lowe's, ask someone to tell/show you.
Garden | Answered 54 minutes ago
Depending on which plants you are going to transplant and how you are going to do it and where you place the containers.
Garden | Answered 21 hours ago
Unsure what 665.1329 is, but it may be a Kenmore part available from Sears.
Example: https://www.searspartsdirect.com/model-number/66513293k114/0582/0130000.html
Depends what you are planting. Most plants should be put in soil when purchased and before they become root bound. However sometimes when you get them, they are crowded in the container. If it's in a soft plastic container, lie it on its side and push down to loosen it. Then gently remove it from the container. Break the roots up at the bottom and loosen the soil there. Score through the roots, from midway to bottom on the 4 sides and gently, slightly separate them to spread them a bit for your hole. Make sure you have a small bump of dirt for that separated part to sit on so there are no big air gaps. Mix a root shock solution in water, and pour into your hole. Once that drains, plant your tomato or flower or whatever, making sure you pack the dirt down around it. Water it with more of the root shock mixture. Put some mulch, about an inch around the top of the plant to keep it from overheating. Water regularly and enjoy.
Garden | Answered Yesterday
Spray adjusting mechanism with WD 40 and turn right then left right then left etc.
Loosen the bolts that hold the starter head and it should then go back unless the spring in starter is broke.
Governor "hunt" is almost always a carburetor or intake air issue. Check the carburetor mounting bolts are not loose (causes vacuum leaks between carb and intake). Suggest you drain and replace fuel with fresh fuel, check for water in fuel. Don't forget to drain the carburetor fuel bowl (may be try this first).
If still hunting, likely carburetor is fouled, try cleaning and or replace.
You should have a 2 stroke oil reservoir, you do not need to mix the fuel, you just have to put unleaded in the tank.
Check out section 6-9 on the manual. here is the link:
http://www.yamaha-motor.com/assets/service/manuals/1998/lit-11626-10-83_379.pdf
Best I can tell it's 2003. Suggest you contact Simplcity (Briggs&Stratton)
http://www.simplicitymfg.com/na/en_us/home.html
262-377-5450
Yardworks Hand Spreader Logo
1 questions posted
Top Yardworks Garden Experts
roeb
john h
Marvin
Marvin
Are you a Yardworks Garden Expert? Answer questions, earn points and help others
View Most Popular
Yardworks Garden
  • Yardworks Garden
Most Popular Question
setting lawm fertilizer yardworks
  • Garden
