20 Most Recent Yardworks Tow Behind Broadcast Spreader Questions & Answers
www.sears.com/yardworks...spreader.../p-S...
(866-523-5218) Yardworks support
Yardworks Tow... | Answered on Jul 06, 2014
Depends what you are planting. Most plants should be put in soil when purchased and before they become root bound. However sometimes when you get them, they are crowded in the container. If it's in a soft plastic container, lie it on its side and push down to loosen it. Then gently remove it from the container. Break the roots up at the bottom and loosen the soil there. Score through the roots, from midway to bottom on the 4 sides and gently, slightly separate them to spread them a bit for your hole. Make sure you have a small bump of dirt for that separated part to sit on so there are no big air gaps. Mix a root shock solution in water, and pour into your hole. Once that drains, plant your tomato or flower or whatever, making sure you pack the dirt down around it. Water it with more of the root shock mixture. Put some mulch, about an inch around the top of the plant to keep it from overheating. Water regularly and enjoy.
Garden | Answered 11 hours ago
The wire or part of it may be inside the string head. Remove cover and check.
Garden | Answered 13 hours ago
Spray adjusting mechanism with WD 40 and turn right then left right then left etc.
Loosen the bolts that hold the starter head and it should then go back unless the spring in starter is broke.
Governor "hunt" is almost always a carburetor or intake air issue. Check the carburetor mounting bolts are not loose (causes vacuum leaks between carb and intake). Suggest you drain and replace fuel with fresh fuel, check for water in fuel. Don't forget to drain the carburetor fuel bowl (may be try this first).
If still hunting, likely carburetor is fouled, try cleaning and or replace.
Garden | Answered 14 hours ago
You should have a 2 stroke oil reservoir, you do not need to mix the fuel, you just have to put unleaded in the tank.
Check out section 6-9 on the manual. here is the link:
http://www.yamaha-motor.com/assets/service/manuals/1998/lit-11626-10-83_379.pdf
Garden | Answered 24 hours ago
Best I can tell it's 2003. Suggest you contact Simplcity (Briggs&Stratton)
http://www.simplicitymfg.com/na/en_us/home.html
262-377-5450
As it appears the fuel pump functions, I suspect either the carburetor float is stuck or the carburetor bowl has mostly filled with water.
First drain fuel bowl. If you capture fuel and transfer to a clear glass container, you may see a water line develop within a few seconds (water on bottom fuel on top).
After fuel empties from bowl leave drain open and crank engine for a few seconds. Additional fuel should flow from the fuel drain. If no fuel then likely the float is stuck. Remove and clean fuel bowl. Check the float and/or inlet needle is not stuck.
If you found water in the fuel bowl, drain fuel tank and refill with fresh fuel. Check all fuel containers for water. Give the fuel container a thorough shake, and pour a sample into glass container. Look for visible water line.
Garden | Answered Yesterday
Yardworks Tow Behind Broadcast Spreader Logo
3 questions posted
Top Yardworks Garden Experts
roeb
john h
Marvin
Marvin
Are you a Yardworks Garden Expert? Answer questions, earn points and help others
View Most Popular
Yardworks Garden
  • Yardworks Garden
Most Popular Question
get drive wheel turn transmission
  • Garden
