20 Most Recent
Hamilton Beach 63221 Stand Mixer Questions & Answers
Como desarmar
primero desmonta el motor de la base. luego en el motor hay tres tornillos en la parte donde entra el cable de alimentacion, quitalos. luego en el cabezal movil quitas un tornillo allen 4mm, en el vastago donde se acoplan los accesorios debes quitar una chabeta y el pin de seguridad y luego halas toda la pieza y abras quitado la tapadera de los engranajes. espero te sirva de algo la respuesta
Can't take apart the body on the mixer
from what i can see you need to remove the mixer head assemble which has a retainer that i havent been able to remove from mine as yet. need a special retainer pliers and you need to remove the rear stand asemble. i have not figured that out yet either. there are no screws under the logo plate. and the screws on the body only loosen the inner assembles, motor and such. this is a tough nut to crack. mine overheats kneading bread and i want to ad a fan.
The mixer blade is out of balance and wabbles
dear sir
With due to respect, I am working in china Gate. Maintenance work. I need to your help of solve this problem.so i request you I NEED cerquit conection diagram SOLVE This problem.
THANKS
Best Regard
Neyaz Ahmed
Chinagat Restorent.
My Email ID-
[email protected]
I have a antique hamilton beach stainless steel
Use DeBruce Polish. DeBruce will remove the rust and pacify the surface. DeBruce also works great on ceramic cook tops grills, chrome windshields and more. We buy DeBruce Polish at debruce polish.com
