20 Most Recent MSR Family Tents Questions & Answers
3answers
Have a greatland tent from target that sleeps 8,
See if this will help you. You can click on the image and a large downloadable image will appear for you. greatland-tent-from-target-sleeps-8-jzinszup44k5nuxgrc5q5c3g-4-0.jpg
10/23/2016 5:45:45 AM • MSR Family Tents • Answered on Oct 23, 2016
I NEED INSTRUCTIONS TO AN OLD AMERICAN CAMPER TENT
Finally figured it out through trial and error. This right here is the only correct explanation given anywhere on the net. First, make sure you have all of your poles. There will be 4 straight green ones, 4 straight blue, 4 straight burgundy with plastic feet, 4 curved yellow, 2 small orange arches, a straight pink and a straight white. Before you start putting the poles together, stake the tent down at every loop point around the base of the tent. There should be 10 of them. Make sure they're fairly tight and the floor of the tent is taught and flat but not so tight that you tear the tent at the seam. Stake 1 corner first. Then put the second stake through the second loop in order and using a firm pressure, pull away from the first stake, along the line of the tent base, make taught and push the second stake into the ground. Repeat until finished. The first pole assembly uses in this order, going out from the yellow arch, which is in the center. From one side of that arch, add one green, then a curved yellow, then another green and a burgundy at the bottom. Do the same from the other side of the center arch piece. This arch outlines the door and goes through the 3 loops on the front of the tent, around the door, so the poles hold the tent up. the loops at the bottom are not for the poles. Every loop around the bottom are where the stakes go to hold it down. For now point the feet towards the back of the tent wherever they will stand on their own. You can fine tune it and firm it up once you get the second arch in place. All green ones should now be used up. For the second arch, do the same thing but use the blue instead of the green. So from the one side of the yellow arch, 1 blue, 1 curved yellow, one blue and one burgundy. Same order from the other side of the arch. Now all the poles should be used up except for the straight pink one and the straight white one. These two go together to make a straight pole that goes through the metal loops attached to the yellow arch pieces and locks the two arch assemblies apart at the top. Now this takes some maneuvering and some word smithery to describe but what you want to do is make sure the feet of the front arch assembly, are pointed towards the back of the tent and stop at the side. The back arch feet will point towards the front of the tent. They both stop about 6 inches BEFORE the center tie down loop on the SIDES of the tent, on either side of the center loop. The front arch will actually lean forward, with the feet pointed behind it and wedged into the ground, right up against the tent at the bottom, move it around until you have a nice firm feel to it. Same with the back arch but this one will lean away from the back of the tent and the feet pointed towards the front. Once you get the back arch into place, it will really firm up and won't budge. Another way to describe it would be that the two arch assemblies feet will point towards each other at the side of the tent, about 6 inches before they reach the center loop on either side. Hope this helped. =) Posted on Jul 04, 2015
8/13/2016 7:28:29 PM • MSR Family Tents • Answered on Aug 13, 2016
American camper tent 2455 setup
7/4/2015 2:15:57 AM • MSR Family Tents • Answered on Jul 04, 2015
Need instructions for a coleman salt lake tent
Are you still in need?
I have just bought one and could send you a photo of the instructions.
9/7/2014 5:41:56 AM • MSR Family Tents • Answered on Sep 07, 2014
DO YOU SUPPLY INSTRUCTION MANUALS FOR TENTS
Here are some manuals for tents - http://fitness.manualsonline.com/manuals/device/tent.html
7/2/2010 2:51:10 PM • MSR Family Tents • Answered on Jul 02, 2010
I have a two man Ozark tent. How do I set it u p?
Two poles. They pass up through the sleeves on the outside of the tent, across the top, through the sleeve on the diagonally opposed side, then each end is stuck into the pocket attached at each corner. They cross at the top. Then the small rain fly attaches with bungees over the top.
6/11/2010 2:03:51 AM • MSR Family Tents • Answered on Jun 11, 2010
Can,t fit frame for an old mexico tent as lost
hello. go to this link http://www.cascadedesigns.com/MSR/Tents/Basecamp-Tents/Board-Room/product
find your tent or one like it and go to that page. then click on more information and you will see a menu to download a free manual. Joe AND happy tenting.
3/22/2010 4:04:00 PM • MSR Family Tents • Answered on Mar 22, 2010
I have a great land tent and we went camping this
did you set tent up at home once and soak ot down with water and let it completely dry before using it?
I have several greatland tents and never have trouble
When it is raining the most important thing to do is to make SURE that nothing is touching the tent material on the inside as to that is what causes water to start to leak thru .Just like a wick. Once the tent gets wet the fibers swell and seal the material stoping the water from coming thru and this getting wet is actually the only waterproofing needed . Taking a tent down wet or damp defeats this and must be setup again and soaked and allowed to dry all over again.As for warranty you have to check the owners manual, The pole having snapped sounds like its possible it was put in place in the wrong spot
1/20/2010 3:14:30 AM • MSR Family Tents • Answered on Jan 20, 2010
Need building instructions for a sunncamp grange
This is as close as I could get. It's the instructions from Sunncamp itself, so I'm guessing they're the instructions that come with the tent, too.
http://www.sunncamp.co.uk/assets/pdfs/instructional/Grange.jpg
Hope this helps. =)
10/10/2009 10:37:25 AM • MSR Family Tents • Answered on Oct 10, 2009
2answers
I have a 60 inch adjustable screw Jack basketball hoop portable and I lowered it down too far how do I raise it back up it won't raise up
Lay it on the ground, gently pull the hoop and turn the screw.
4/18/2024 10:44:09 AM • Sport & Outdoor... • Answered 5 hours ago
Hi we need a manual
Hi Linda, i have the same 1983 Travelaire motorhome Econoline F-350 26ft and are in search of the Shop/owners manual ... Do you know where to find one ? I am located in BC Canada Reg 250-379-2971 [email protected] if you can contact me ?
3/23/2024 12:45:15 AM • Sport & Outdoor... • Answered on Mar 23, 2024
3answers
How do i pick out a tennis racket?
This website has a fabulous guide to picking out a tennis racket!http://www.wilson.com/en-us/tennis/rackets/racket-selector/
3/11/2024 10:21:05 AM • Sport & Outdoor... • Answered on Mar 11, 2024
MSR Family Tents Logo
Popular Tags
21 questions posted
Top MSR Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a MSR Sport and Outdoor - Other Expert? Answer questions, earn points and help others
View Most Popular
  • MSR Sport & Outdoor - Others
Most Popular Question
need instructions old american camper
  • Sport & Outdoor - Others
