20 Most Recent Kelty Teton 2 Tent Questions & Answers
Tent resealing
Just get a few cans of Camp Dry or a good spray tent waterproofing. Set up the tent and brush the flaky stuff off and spray the whole tent. Allow it to dry completely before refolding. I usually get about 3 years out of one application. The seam tape can be resecured with seam repair products. There are gels, tapes and what look like glue sticks.
2/7/2009 3:10:02 AM • Kelty Teton 2... • Answered on Feb 07, 2009
Have huge Kelty ridgeway tent, maybe 20 yrs old. Heavy metal poles labeled red, green, blue. Can’t find set up instructions. Help!
I believe I have the same Ridgeway tent - over 20 years old. Red-, Blue- and Green-labeled poles. Best setup will require at least 2 persons. Here is a quick guide to setup: 1. First, stake the tent floor down making sure it is taut. 2. Center poles are labeled with Blue dots. There are 3 separate poles that fit through the center channel - 1 straight pole with 'male' connectors on each end (this will be in the middle), and 2 poles with curved 'female' ends. The curved ends need to slip through the center loops (there's a 'hook' to hold the loop). The center upright poles consist of a bottom pole (which should have a cap on one end and an adjustable ring on the other) and a 2-piece snap pole (with grooves on one end). Make sure to slip the pole with the grooves through the adjust ring (this will allow adjusting the height of the center of the tent). There are also 2 strings at the center of the tent about a foot above the ground. Tie these strings around the upright center pole to ensure that the center upright pole doesn't separate too far from the tent. 3. Poles with Red dots are for the ends of the tent. There is a curved 2-piece snap pole that slips through the end channel. Then, you have a 3-piece straight snap pole that attaches to each side of the curved pole. The bottom end of the straight pole should be placed about a 1.5 feet from the bottom of the center pole (at about a 45-degree angle). The door ends are essentially 'leaning' outward from the center. 4. Poles with Green dots are for the extended door cover on the large door side. These are 2 snap poles with ends that fit through the grommet holes of the cover.Photos of erected tent are attached. kelty-ridgeway-1-undefined-undefined-0.jpg kelty-ridgeway-3-undefined-undefined-2.jpgWe don't use our tent very often, but my son just took it camping and it was a breeze to set up. If you still have the plastic stakes, I would recommend replacing those with metal stakes, as the plastic stakes break easily. Also, you may need to find a rain fly that fits the tent.
8/30/2020 9:25:47 PM • Kelty Sport &... • Answered on Aug 30, 2020
Does anybody have instruction for Ridgeway by Kelty model 293719
Go to ehow.com.and search for ridgeway. You'll find it there.
6/29/2015 12:47:38 AM • Kelty Sport &... • Answered on Jun 29, 2015
0answers
2answers
I have a 60 inch adjustable screw Jack basketball hoop portable and I lowered it down too far how do I raise it back up it won't raise up
Lay it on the ground, gently pull the hoop and turn the screw.
4/18/2024 10:44:09 AM • Sport & Outdoor... • Answered on Apr 18, 2024
Hi we need a manual
Hi Linda, i have the same 1983 Travelaire motorhome Econoline F-350 26ft and are in search of the Shop/owners manual ... Do you know where to find one ? I am located in BC Canada Reg 250-379-2971 [email protected] if you can contact me ?
3/23/2024 12:45:15 AM • Sport & Outdoor... • Answered on Mar 23, 2024
3answers
How do i pick out a tennis racket?
This website has a fabulous guide to picking out a tennis racket!http://www.wilson.com/en-us/tennis/rackets/racket-selector/
3/11/2024 10:21:05 AM • Sport & Outdoor... • Answered on Mar 11, 2024
Queria o manual em pdf da barraca ozark trail hk-5100, onde posso conseguir?
English only on Fixya please.
Ozark Trail Tent User Manuals Download
ManualsLib https://www.manualslib.com > ... > Ozark Trail Manuals Download 66 Ozark Trail Tent PDF manuals. User manuals, Ozark Trail Tent Operating guides and Service manuals. https://www.google.com/search?q=Ozark+Trail+HK-5100+tent+instructions ..
3/5/2024 10:45:39 PM • Sport & Outdoor... • Answered on Mar 05, 2024
Where is the femur located
Good day are you referring to the human body, if so the femur is located in the thigh.
2/20/2024 5:30:32 PM • Sport & Outdoor... • Answered on Feb 20, 2024
How can I maintain my pool table at top condition?
In order to maintain the condition of your table and prolong its lifetime you should avoid eating above the table, putting drinks of ash trends on the sides of the table, and generally try not to harm the cloth with the cue. In addition you can clean and vacuum the table from the outside once a month, this Is what I'm doing to my table.
2/7/2024 10:05:02 AM • Sport & Outdoor... • Answered on Feb 07, 2024
Kelty Teton 2 Tent Logo
2 questions posted
Popular Products
Top Kelty Sport & Outdoor - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kelty Sport and Outdoor - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Kelty Sport & Outdoor - Others
Most Popular Question
tent resealing
  • Sport & Outdoor - Others
