20 Most Recent Kalamazoo Outdoor Gourmet Modular Outdoor Kitchen System Back Panel for 24"" Appliance" Questions & Answers
Hello John, before changing the belt, clean the surfaces where the belt will work?
You should clean the belt, with a little alcohol, on the plate, then clean the motor pulley, also with alcohol, if you can remove the plate, check that the axis of rotation does not generate jumps or hardening
I hope the information has been useful
Greetings Franco Dosil
Hola John, antes de cambiar la correa, limpio las superficies donde va a trabajar la correa?
Debe limpiar en el plato, el sector donde trabaja la correa, con un poca de alcohol , luego limpie la polea del motor, tambien con alcohol, si puede retirar el plato, compruebe que el eje de rotacion no genere saltos o endurecimientos
Espero que le haya servido la informacion
Saludos Franco Dosil
Audio Players &... | Answered 5 hours ago
Click on the link to add your song
https://soundcloud.com/user-330214342/emife-calling-over
Audio Players &... | Answered 17 hours ago
Believe it or not... Try this: (it's happened to me)
Take all the remotes (tv, cable, stereo etc.) out of the room and into a drawer or under a pillow. If it solves the problem... replace the batteries in the remotes. Problem solved!!! Sometimes when some remotes get low on battery juice, they send out random signals without you pressing any buttons. Hope it works.
Audio Players &... | Answered 20 hours ago
Free instructions for one model yogurella. You can respond with more information to add to your question using the Comment menu. http://www.manualsdir.com/manuals/20456/ariete-yogurella-metal-620.html?page=13
Audio Players &... | Answered 2 days ago
Is your PC Bluetooth-enabled ? If not, you will have to buy a USB Bluetooth adapter for your PC.
Try Googling (denon)(pma 355uk)(manual) without parens.
I believe this unit employs an optical sensor to detect tape end.
Clean this off to. It looks like a transparent post positioned along the tape path. Reset the counter to zero and fast forward tape to end. Rewind, and try to play tape as normal
Audio Players &... | Answered 3 days ago
Hi, there
Since your unit has a CD player, the problem with both the turntable and cassette deck is probably due to the rubber belts that turn both mechanisms losing elasticity or have broken over time (or in the worst case scenario, turned to goo). I don't know your model manufacturer, but turntables often have a clip, or some sort of apparatus, that you can remove to lift the turntable platter up and off. If you can do that, you will be able to see what shape the turntable belt is in. For the cassette deck, more intricate disassembly is required. Replacement belts for both can often be found on eBay or other online sources.I found a video for an ion turntable that might have a similar belt system.
Hello Billy, obviously your STR-K502P, has problems in the main power supply, control you have to remove the cover and look for a fuse indicated as; F901 FUSE (6.3Amp / 125V) and fix it is burned, if so, before replacing it, you would have to get a lamp holder and an incandescent lamp of 200 watts, the old lamps that bring filament, and connect the cables of the holder lamp to the ends of the fuse holder, the lamp replaces the fuse (serial lamp), you connect the STR-K502P to the power network and turn it on, if the lamp turns on completely and stays that way, it is very likely that there are components damaged and are generating a short circuit, in this case I suggest you look for a specialized technical service
If, on the other hand, the lamp is turned on and off or the intensity of the initial flash is reduced, this would give a guideline that there is possibly no short circuit, you can test the operation of the STR-K502P in this situation, if you can hear it, then replace it the fuse, its value is 6.3 Ampere / 125Volts
Once this is done, do not use the STR-K502P, without first checking all the cables and connections of the speakers, corroborating that you do not have any short circuit in them
I hope you can solve it
Hola Billy, evidentemente tu STR-K502P, tiene problemas en la fuente de alimentaci?n principal,controla tienes que sacar la tapa y buscar un fusible indicado como; F901 FUSE de (6.3Amp/125V) y f?jate se esta quemado, de ser as?, antes de reemplazarlo, tendr?as que conseguir un porta lamparas y una lampara incandescente de 200 watts, las viejas lamparas que traen filamento, y conectar los cables del porta lampara a los extremos del porta fusible, la lampara reemplaza al fusible (lampara serie), conectas el STR-K502P a la red de energ?a y lo enciendes, si la lampara se prende por completo y se queda as?, es muy probable que haya componentes da?ados y est?n generando un cortocircuito, en este caso te sugiero que busques un servicio t?cnico especializado
Si por el contrario, la lampara se prende y se apaga o baja la intensidad del encendido inicial, esto dar?a pauta que posiblemente no hay corto circuito, puedes probar en esta situaci?n el funcionamiento del STR-K502P, si logras que puedas escucharlo, entonces reemplaza el fusible, su valor es 6,3 Amper/ 125Volts
Hecho esto, no utilices el STR-K502P, sin antes controlar todos los cables y conexiones de los parlantes, corroborando que no tengas alg?n cortocircuito en ellos
Espero que lo puedas resolver
Lorraine McKellar wants answers to this question
Hi Lorraine, I sent you the link so you can get the DVB-T202 user manual
Hola Lorraine, te envio el link para que puedas obtener el manual de usuario del DVB-T202
https://data2.manualslib.com/pdf3/79/7820/781968-august/dvbt202.pdf?25f00993f17422491b49e230e03de502&take=binary
Audio Players &... | Answered on Apr 19, 2019
You have to complete the id3 tags of songs. Just follow below steps to do that. If you want to edit ID3 tags with iTunes, the following steps will guide you on how to complete this task in details.
1. Run iTunes and find the song which you would like to edit its information by click on it. Or you can choose multiple songs at the same for editing.
2. When the songs that you would like to edit have been selected, you can refer to the steps as below:
I.Enter the "File" menu and choose "Get Info".
II.Choose "Command + I" on the keyboard of Mac or select "Control + I" on the keyboard of computer.
III.Hold down the option "Control" while you are clicking, or just have right click.
3. No matter which method you have chosen, the window of "Get Info" will pop up, where all the metadata of the song will be listed.
You are allowed to edit the information of the selected songs, which is known as ID3 tags.
Something about ID3 tags editing must be known as below:
1. The tab about "Details" which is also called Info in the older version is the place where the info of iTunes song is edited. The information including title, artist, year, album and more can be edited here. You just need to click on the fields which you need to add or edit, then the information will be changed by your words entering.
2. You can find album art of the song in the "Artwork" tabs. You can click on the button "Add Artwork" and choose images from your hard drive to add new art to the song. Also, the built-in tool of album art can be used to add art to the songs or album automatically.
3. The lyrics of the song are listed in the Lyrics tab. Taking down the lyrics automatically is the function in the new version of iTunes. While the lyrics must be copied and pasted to this field in the older versions of iTunes. Additionally, the built-in lyrics can be overridden by clicking on the option "Custom lyrics" to your own lyrics.
4. The song's volume can be controlled in the "Options" tab. Through the automatic equalizer setting, you can determine the beginning time and the ending time of the song. Choose the "Skip" option in the shuffling box so that the song can be prevented to show up in next or in the shuffle playback.
5. In the "Sorting" tab, you can see how the song, the artist and the album are shown in iTunes library after sorting out. For instance, a guest star may be included in the Artist ID3 tag of the song. This would be displayed as a separate part in iTunes. If the artist and the album name are added to the fields of "Sort Artist" and "Sort Album", all songs will be listed together in one album view and you don't need to change the ID3 tags permanently.
6. When choosing the "File" tab, you can see the information including song time, file type and bit rate and more are listed here. This is a new option in iTunes 12.
7. More song information can be added via moving the arrow key which locates on the left bottom of the iTunes 12 window.
8. The Video tab can only be applied to edit the video tags in iTunes library. The episodes from the same season can be put together in this field.
9. When all the editing is completed, you can save them by clicking on "OK" button on the bottom of the iTunes window.
edit-id3-tags-in-the-fields-2-5qo4itlp1ucrbflot1afpynl-2-0.jpg For more methods, check: How to Edit ID3 Tags in iTunes
Audio Players &... | Answered on Apr 18, 2019
Kalamazoo Outdoor Gourmet Modular Outdoor Kitchen System Back Panel for 24"" Appliance" Logo
0 questions posted
Top Kalamazoo Outdoor Gourmet Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Kalamazoo Outdoor Gourmet Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Kalamazoo Outdoor Gourmet Audio Players & Recorders
Most Popular Question
kd 2055 new belt but sound still
  • Audio Players & Recorders
