20 Most Recent Crosley Replacement Clothes Dryer Thermal Fuse Hi-Limit Thermostat for Dryers Questions & Answers
The timer will not advance and wont get hot
if the dryer is only getting 110v instead of 220v it will run but not heat check your power and breaker
11/4/2015 12:27:21 PM • Crosley... • Answered on Nov 04, 2015
Instruction manual for danube dryer
Danube dryer machine has alarm Al-2
5/16/2019 7:04:12 AM • Crosley Dryers • Answered on May 16, 2019
The power button on the dryer of my Crosley MLC275CW5 is stuck. How do I remove the panel to free it up or repace if neccessary?
Model # is incomplete. Missing a letter to go with MLC or a number with 275.
10/5/2018 4:47:22 PM • Crosley Dryers • Answered on Oct 05, 2018
2answers
Crosley ced126sxq1 Dryer Doesn't heat at all, Air dry Doesn't work. Any Advice?
  1. Sometimes it's cheaper to hire somebody that knows what they are doing instead of the I thought idea. I have done that with my car and found I thought cost me more than the simple problem it was.
9/25/2018 1:26:17 PM • Crosley Dryers • Answered on Sep 25, 2018
Does the Crosley natural gas dryer model CDG8563MQO, serial no. MR0801034 have a pilot light or an igniter?
Do you here is click when you turn on a burner, if so it has electronic ignition system
7/20/2018 5:56:12 PM • Crosley Dryers • Answered on Jul 20, 2018
Model #CEDX563JQ0 Crosley Dryer won't heat and getting current
I would check to be sure you have 220v going to Dryer. Possibly timer problem as heat circuit runs through that too.
8/27/2017 7:42:34 PM • Crosley Dryers • Answered on Aug 27, 2017
Crosley large capacity dryer turns on,drum turns,makes humming noise...
sounds like could be bad windings on motor also check belt switch 26366927-2c3mgo1ucomcxgarbvmsr4e2-1-0.jpg
12/13/2016 3:49:30 AM • Crosley Dryers • Answered on Dec 13, 2016
Crosley heavy duty dryer blows out heat but will not spin
Check the dryer drum drive belt it may be broken or the dryer drum drive motor may have failed
10/18/2016 8:13:10 PM • Crosley Dryers • Answered on Oct 18, 2016
Crosley Replacement Clothes Dryer Thermal Fuse Hi-Limit Thermostat for Dryers Logo
5 questions posted
Top Crosley Dryers Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
View Most Popular
Crosley Dryers
  • Crosley Dryers
Most Popular Question
timer will not advance wont get hot
  • Dryers
