20 Most Recent Straight Talk Huawei Ascend Y Cell Phone Questions & Answers
4answers
I can't download apps. My phone only has enough space for about two apps. Do I need a card or something?
Insert and extra micro memory card to the phone. You can download the aps, and store it there. Gopakumar Gopalan Google
11/29/2016 1:51:59 PM • Straight Talk... • Answered on Nov 29, 2016
Cant get into gmail page wont sync?
Write your answer...reboot your phone .
12/3/2015 1:40:54 PM • Straight Talk... • Answered on Dec 03, 2015
Retrieve deleted voicemail
Once you delete it, it is gone forever.
11/27/2015 11:29:20 AM • Straight Talk... • Answered on Nov 27, 2015
2answers
I can't delete my pictures off my Huawei ascend straight talk phone. h866c.
Go to ur Gmail app. At bottom bring up account settings. Then click the Gmail account pull up the sync settings. Unchecked pacosa web photos. Then try again to delete pics. I had this issue... when u sync to pacosa ur pics send to ur Gmail n can't b erased. Hope I helps.
10/1/2015 7:37:59 PM • Straight Talk... • Answered on Oct 01, 2015
The home screen where my data switch is gone so i
Refer to manufacturer website for included apps and instructions for possible updates.
8/31/2015 4:23:31 PM • Straight Talk... • Answered on Aug 31, 2015
I dont know the screen lock pin for my huawei phone help?
If you know the Gmail address and password that was used to initialize the phone, you can use Google's Android Device Manager to erase and reset it. Without these credentials, you will have to use the phone's external softkeys to restore it to factory settings. Google Android Device Manager Google's Android Manager is able to find, lock and erase the Huawei smartphone through the use of locating features on most Huawei Android phones. Sign into the Web app using the Gmail address and password (link in Resources) and -- if there is more than one Android device registered to the account -- select the correct device name from the drop-down menu at the top. Click the "Erase" option once the phone has been located by Google. This won't work unless you've registered the phone with Android Manager in the past. Without the Google Credentials Without Google account access, however, you'll need to reset the device using its external buttons. This procedure varies based on model, but typically involves simultaneously holding down a combination of buttons until the device enters Recovery Mode. Huawei's Valiant and Vitria models, for example, both require you to push the "Volume Up" and the "Power" keys for several seconds until an Android robot with a red error sign appears on the screen. At this point, you can navigate the recovery meny using the "Volume Up," "Volume Down" and "Power" buttons, and select the option to erase the device.
5/25/2015 12:09:34 PM • Straight Talk... • Answered on May 25, 2015
I added more channels on my television but they wont come on
Just because you added them don't mean that they are available or broadcasting. First of all where are you getting the signal from. Cable or over the air (antenna) ? If you are receiving over air free TV you may not have a strong enough signal. The best way to add channels is to do a scan and let your TV find them automatically. For over air broadcast sometimes your TV will find channels that are not quite a strong enough signal to play depending on your location from the the station transmitter. Note that relocating the receiving antenna or getting a better one will usually fix this problem. Now if your receiving Cable then you have another issue. The only channels that you will be able to receive directly with your TV is the ones that come with the basic service the rest will be scrambled and will require that you pay a subscription an be connected through one of there box's which contains the descrambler that can turn on or off from the cable company office. Hope this helps.
5/22/2015 7:31:23 AM • Straight Talk... • Answered on May 22, 2015
CAN ANYONE TELL ME HOW TO MAKE THIS PHONE A TOUCH SCREEN
If you are talking about the Huawei Ascend Y, it already is a touchscreen
4/5/2015 6:57:31 AM • Straight Talk... • Answered on Apr 05, 2015
My Straight Talk Huawei says it has no service but was working last night and now just wont send messages what is going on
1. Did you pay the bill? Check with them, maybe your service got cut off. 2. If it isn't #1, Take the SIM card out and put it back again, maybe the SIM card is faulty. 3. If possible, go to settings, mobile network, and choose to search for your wireless carrier, once it pop up, tap it to register. 4. You also must make sure your APN is in order. And have the correct APN check for Straight Talk.
10/10/2014 7:11:21 PM • Straight Talk... • Answered on Oct 10, 2014
I dropped my phone. Why won't the display work now?
I think you should go to your nearest phone shop,and show them your phone because I think it's a technical problem
6/3/2014 2:00:06 AM • Straight Talk... • Answered on Jun 03, 2014
My home buttton will not work
You may have to take this to the phone store and ask them to run a continuity test of the keys. If the key pad is defective, so goes the phone.
3/17/2014 8:55:35 PM • Straight Talk... • Answered on Mar 17, 2014
Phone will not recognise sim card
I had the same problem with my NEW Huawei Ascend. My solution was that I had to trade it for another new one. I wouldn't have even known about it since it was my first experience with a smart phone. But I wanted a bit more memory and that is how I realized it wasn't recognizing the card. Hope this helps.
3/14/2014 12:45:36 PM • Straight Talk... • Answered on Mar 14, 2014
Any downloads How do I download them from text messages.
I can't send picture text or receive them on my Huawei phone.
3/5/2014 7:00:54 PM • Straight Talk... • Answered on Mar 05, 2014
I keep getting the low on space an have to keep clearing data
stop updating or buy a phone with higher memory storage
2/20/2014 6:06:57 AM • Straight Talk... • Answered on Feb 20, 2014
Straight Talk Huawei Ascend Y Cell Phone Logo
115 questions posted
Top Straight Talk Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Straight Talk Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Straight Talk Cell Phones
Most Popular Question
download apps phone only enough space
  • Cell Phones
