20 Most Recent
Sony Xperia Tipo Dual ST21i2 Black Android 4.0.3 Dual SIM unlocked phone Questions & Answers
There is a sensor problem in my sony xperia st21i
perform a soft reset, this should resolve the problem. the button is located behind the micro sd card slot cover, small red, you can't miss it. search on line regarding Xperia soft reset instructions, pretty simple and fast. you won't loose any data.
Why does ST21i2 restarts itself
Restarts on Android happen sometimes just like with any other OS(windows,etc.) if it constantly restarts itself(Bootloop) then try a factory restore.
How to find pin from access point option in wifi settings of tipo dual ?
It is not possible to extract the stored password once connected to the network. There was a loophole previously in which wifi passwords can be accessed from the phone through an xml.
instead now to connect to your home network you should use the wps button on your router and connect it.
Touch Screen
It seems to be a hardware problem. However, you could try restoring your system, or installing a ROM.
It's quite weird that your screen stops working properly because of the charger. Good luck.
Sony Hbd tz510 remote code
The remote control code for Sony HBD-TZ510 home theater system may vary depending on the brand of the remote you are using. Here are a few common remote control codes that may work:
To program your remote, follow these steps:
- Turn on your Sony HBD-TZ510 home theater system.
- Press and hold the "Code Search" button on your remote control until the indicator light illuminates.
- Press the "DVD" or "AUX" button on your remote to select the device you want to program.
- Enter the four-digit code using the number buttons on your remote.
- Press the "Power" button to test if the code is correct. The device should turn off if the code is correct.
- If the device turns off, press the "Enter" button to save the code. The indicator light will turn off.
- If the device does not turn off, repeat steps 4-6 with a different code until you find the correct one.
Note: If you do not have the original remote control that came with your Sony HBD-TZ510, you may need to purchase a universal remote control that is compatible with your device.
I need to know how to use rm ed007 remote to set up my sony dvd to play on sony bravia tv
The "rm ed007" remote that you mentioned is most likely a universal remote control, which can be programmed to control multiple devices, including your Sony DVD player and Sony Bravia TV.
To program the remote to control your Sony DVD player, you can follow these steps:
- Turn on your Sony DVD player.
- Locate the code for your Sony DVD player in the code list provided with the universal remote.
- Press and hold the "Code Search" or "Setup" button on the universal remote until the indicator light turns on.
- Enter the code for your Sony DVD player using the number buttons on the remote.
- Test the buttons on the remote to make sure that they are controlling the Sony DVD player as expected.
To program the remote to control your Sony Bravia TV, you can follow these steps:
- Turn on your Sony Bravia TV.
- Locate the code for your Sony Bravia TV in the code list provided with the universal remote.
- Enter the code for your Sony Bravia TV using the number buttons on the remote.
- Test the buttons on the remote to make sure that they are controlling the Sony Bravia TV as expected.
