20 Most Recent
Sensaphone Alarm Monitor - Model 400 - FGD-0400 Questions & Answers
Why is the green light going on and off on my senaphone modle 400?
I'm assuming this is the System On LED on the Sensaphone 400. That would indicate that the unit is in standby mode. All you will need to do is Press the [Run/Standby] key this will turn the Sensaphone back On. The system On LED on the Sensaphone 400 & 800 flash when the device is in standby mode, solid lit when the device is On. If these units are in standby, they do not recognize alarms nor do they pick up the phone on a dial in.
Here is a link to the manual if needed
Support Sensaphone 400 Monitoring System
Troubleshooting stanley bs16bs
This could be due to several reasons such as a faulty battery, a problem with the charger itself, or an issue with the connection between the charger and the battery. Here are some general steps you can take to troubleshoot this issue:
Check the Battery: Ensure that the battery you're trying to charge is not faulty. If possible, try charging a different battery with the same charger to see if the problem persists.
Check the Charger: Make sure the charger is functioning properly. If you have another charger, try using it to charge the battery.
Check the Connection: Ensure that the connections between the charger and the battery are secure and clean. Any dirt or corrosion could interfere with the charging process.
Reset the Charger: Unplug the charger, wait a few moments, and then plug it back in. This can sometimes resolve minor technical issues.
https://www.manua.ls/stanley/bc15bs/manual
If unresolved, you might contact Stanley customer support.
4/18/2024 3:05:03 PM •
Cell Phones
Answered
6 hours ago
I need the reset code for Cash Power 2000 prepaid electricity meter.
How do I reset my cash power meter?
Reset your meter by pressing I, BLUE or # button, this is needed to ensure the 2 parts of your meter initiate connection again. This action should reset your meter. Please note, this error is not a technical error and you should never insist a technician comes out for this.
4/17/2024 6:33:31 AM •
Cell Phones
Answered
Yesterday
GPX Media Player model MT851B. My touchscreen doesn't respond on it. How do I fix it
There doesn't seem to be anything online to suggest how to do a reset or recalibrate the screen.
You could try three things
Look for a tiny Reset hole in the back.
Connect it to a computer and in Windows Explorer see if the is any useful right click commands?
Or leave it running until it runs out of power, wait 24 hours before recharging.
4/9/2024 3:30:50 AM •
Cell Phones
Answered
on Apr 09, 2024
Track my phone thats is off
This can't be done. If the phone is powered off or the battery dies, the GPS isn't working and it can't be tracked. If you go into 'Find my Phone' you can see the last position it was located, but you won't be able to get a current position if the power is off or dead.
4/8/2024 2:35:20 PM •
Cell Phones
Answered
on Apr 08, 2024
I bought my Mom a Flip phone and she has Straight Talk service. The phone will not ring when someone calls in. HELP!
I would check 2 things. First, make sure the phone doesn't have a 'sound off' button on it. Many phones have a button on the outside that turns off any rings, beeps, etc. Make sure if that exists that its not turned on. If you either don't find one or its not engaged, then I would call Straight talk and have them ensure that the cell service is properly 'provisioned' for your Mom's phone. Sometimes the cell companies screw up and the phone won't ring. Either of those will hopefully do the trick!
4/8/2024 2:33:38 PM •
Cell Phones
Answered
on Apr 08, 2024
