20 Most Recent
Nokia Asha 311 Cellular Phone - Wi-Fi - 3G - Bar - Grey - SIM-free - 7 Questions & Answers
Why nokia asha 311 keeps turning off when i turn it on ?
If the phone is new,it is a factory fault,its technical.Return it to your supplier but if its an old phone ,it can be your battery,try a new one or it can also be the power supply so you will then have to consult with your nearby phone technician.
Whatsapp download
Normally whatsapp uses a lot Memory when working,so try to Disable some background Processes when U open the App.If It Not Work,Try By Formatting ur MMC!
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
