20 Most Recent
HTC Windows Phone 8X Questions & Answers
HTC windows 8x
I had a similar problem with my tablet, however it was a generic android tablet , no branding. Yours is a decent phone so you should be able to flash boot your phone. You should google how to do it as I'm no expert. P.S. I do know that you have a problem with your boot processes, so you can narrowyour searchesHope i could help
Dropped htc windows phone in water any tips
Turn it off and remove the battery pronto. Next, fill a zip-lock bag with rice. Lay the bag down flat and set the phone inside the bag, resting on top of the rice. Seal the bag, and leave it that way for two days. The rice will absorb the moisture in the phone, and if you're lucky, it'll be completely fine.
Htc pm23300 unlock code
You can get the unlock code for your HTC Windows phone 8X phone from
OnlineGSMUnlock.com here you need to specify your country,Network name to which it is locked,IMEI number of your phone.
Error code 0x80070005
corrupted windows files. I would rerun upgrade make sure you are plugged into power or try a full phone reset,, similar advice here. Doubt if windows phone will allow the repair tool though. http://www.wiki-errors.com/wiki-errors.php?wiki=0x80070005
