20 Most Recent Jura Capresso Impressa X90 Espresso Machine Questions & Answers
Hi, I made a video how to fix your Jura step by step, good luck.
http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Jura Capresso... | Answered on Mar 23, 2015
Hi, a video how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Hi, I made a video how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Clean it with a paper clip or pin
Jura Capresso... | Answered on Dec 11, 2014
You did very well to switch it off since steam could harm the electronics.
However this is a frequent problem with espresso machines. The steam is coming from the boiler with pressure by tube made from Teflon and it is secure on the steam wand union with the easy secure system. This is using an o ring rubber and a copper ring forced in the union and secured with a clip.
Sometimes the clip get out of this place so the Teflon tube is out too or the o ring it is have a leak and in both cases the steam is all over inside the machine.
The problem is sometime caused because the steam wand becomes goggled by dry milk so the steam with pressure will force the tube to come out from a loose point.
Therefore your machine actually have not any serious problem the only thing is to remove the top panel find the loose tube and put it back is place. If you don’t see the clip on place you search for it around the bottom of your machine.
Use also a thin paper clip inside the steam wand so it will open completely and try to use the machine without the panels in order to visual check that the steam is coming from steam wand and you don’t have any steam leaks in other places.
If you are not capable doing the above yourself then if you ask a professional do it for you just take care to charge you only a labor cost of 30 min and maybe a new clip.
Take care and if you need anything more just comment it back.
Jura Capresso... | Answered on Nov 08, 2014
if the hopper is not sitting properly it will not turn on. there is a small micro switch on the top part of the machine which is activated by one of the upper lids
Jura Capresso... | Answered on Mar 04, 2014
You need to run the Decalcyfying program. Push and hold the button with the symbol that looks like a tube with small dots inside. You will get the message empty tray and empty grounds. Do so, and put everything back. The message Solvent or Agent in tank will be displayed. Meassure up 700ml water in a container, put 3 Descaling tablets in the water and let it be completly desolved before you pour this into the empty watertank. It`s very important that you don`t use more liquid, this will make the program run forever. When the solvent is in the tank, push the buttoun again, and the program starts. After a while (20 minutes or so) you will be asked to empty tray/grounds again and to fill the watertank. At this point you can fill up the watertank, this will not affect the running of the program. In the end, you must empty tray/grounds again, and after this the machine is heating up and ready to use. Good luck!
Jura Capresso... | Answered on Nov 23, 2013
Too Much Water .....
Jura Capresso... | Answered on Nov 02, 2013
Too much water .
Clean the two left side contacts inside the housing where the tray fits. Note...Unplug from wall first.
Jura Capresso... | Answered on Jun 08, 2013
Have you run a decal recently? This normally happens when a small particle (normally) an undesolved piece of the decal tablet is stuck in the flow meter, or sensor.
You can try and run warm water through the system and after about half a tank it should be sorted out.
Hello, make sure the magnet in the water tank moves freely, sometimes it gets stuck with deposits, its a small black rectangle near the base. if its not free, you need to put some descaling solution it the tank to clear it.
Jura Capresso... | Answered on Jan 21, 2013
Jura Capresso Impressa X90 Espresso Machine Logo
47 questions posted
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Impressa Jura Capresso
  • Impressa Jura Capresso
Most Popular Question
get message unit cal fied
  • Coffee Makers & Espresso Machines
