20 Most Recent Horizon T203 Treadmill Questions & Answers
How do i program users?
Call Horizon Fitness
  1. 800.244.4192
Horizon manual list
1/4/2014 4:56:24 AM • Horizon T203... • Answered on Jan 04, 2014
Keeps asking me select user, then it restarts again
Reset it. and follow this steps and fix it. God bless you 1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen. ·3 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
12/10/2013 12:05:24 PM • Horizon T203... • Answered on Dec 10, 2013
Knocking noise
see the video attached. However LUBE the rollers bearing front+back with wd-40God bless you
11/13/2013 10:48:15 AM • Horizon T203... • Answered on Nov 13, 2013
Horizon CT 7.2 treadmill - the buttons that are located between the handles (where is the start button) aren't working.
Question edited for clarity. It is a Treadmill, not a THREADmill. Question moved from Video Consoles. Not a good idea posting your email address as a user name!! This site get 11 million viewers a year including thousands looking for addresses to harvest and spam. Fortunately most spare parts are still available. I was looking to see how the console gets its power, but it is not shown. Some use a small wall plug in transformer, so use a board transformer of the mains supply to the whole treadmill. You would need to trace with a multimeter. You could also clean behind the button with switch cleaner. https://www.fitnessrepairparts.com/equipment/Select/26678/Horizon/Horizon-CT7.2-2013-TM685B https://www.fitnessrepairparts.com/equipment/26678/diagrams/44632 https://www.google.com/search?q=Horizon+CT+7.2+treadmill+parts ..
4/3/2024 5:43:36 PM • Horizon Exercise... • Answered on Apr 03, 2024
Horizon Fitness 4.1t Treadmill not moving
A bit obvious but ... is the motor connected correctly I wonder.
12/27/2023 9:33:04 AM • Horizon Exercise... • Answered on Dec 27, 2023
Does the Horizon 7.0 AT have a fuse on the MCB?
Hey Sharon,Hope so you're doing fine, there is typically no separate fuse on the MCB (Main Circuit Board). The MCB itself is responsible for controlling the incline and belt functions of the treadmill. If the top board turns on but the incline and belt do not run, and the MCB is flashing a safety key error message, it suggests that the safety key might not be properly engaged or there could be an issue with the safety key sensor.To troubleshoot the problem, make sure the safety key is securely inserted into its slot and properly aligned. Check for any visible damage or debris that might be obstructing the safety key sensor. If the issue persists, it is recommended to consult the treadmill's user manual or contact Horizon customer support for further assistance. They can provide specific troubleshooting steps or guide you through any potential repairs or replacements that may be necessary.Hope so this will work for you!Regards,Bryce JuneCEO & Founder of https://bbcorhitter.com/
6/8/2023 3:59:50 PM • Horizon Exercise... • Answered on Jun 08, 2023
How do I know which board is defective on my DT680 Horizon Treadmill
by testing with a multi-meter
5/5/2023 12:02:16 PM • Horizon Exercise... • Answered on May 05, 2023
2answers
Horizon GS1035T Treadmill. Were are the fuses on it please?
https://support.horizonfitness.com/hc/en-us/articles/4410673893261-Horizon-Fitness-GS1035T-Treadmill
4/26/2023 12:12:08 AM • Horizon Exercise... • Answered on Apr 26, 2023
Horizon T202-4 motor hot and burning smell
It sounds like there may be a problem with the control board or the wiring of the treadmill. The high temperatures you are experiencing on the control board and motor are not normal, and can cause damage to the machine. Here are a few things you can try to troubleshoot the issue:
  1. Check the wiring of the treadmill to ensure that all connections are secure and that there is no damage to the wires.
  2. Make sure the motor is properly installed and that the belt is aligned and tightened correctly.
  3. Check the ventilation of the motor and control board to ensure that they are not overheating due to a lack of proper airflow.
  4. Check the amp draw of the motor and compare it to the specifications of the machine to ensure that it is operating within normal range.
  5. If the problem persists, it may be best to contact the manufacturer or a qualified technician for further assistance.
It's also worth noting that, it may be the case that the new motor sent to you is faulty, or that the problem is not the motor itself but with another component of the treadmill. It may be a good idea to have a professional look into this issue and diagnose the problem before trying to replace another component.
1/23/2023 10:05:42 PM • Horizon Exercise... • Answered on Jan 23, 2023
Horizon Quantum Incline not working
The issue you are experiencing with the incline motor on your Horizon Quantum II treadmill could be caused by a variety of factors, including a problem with the motor itself, the control board, or the wiring. Here are a few steps you can try to troubleshoot the problem:
  1. Check the motor: As you mentioned, you were able to operate the motor when 230V was applied, which suggests that the motor itself may be functioning properly. However, you may want to test the motor further to confirm that it is not the cause of the issue.
  2. Check the control board: The control board is responsible for controlling the incline motor, as well as other components of the treadmill. If the control board is damaged or malfunctioning, it could be causing the issue you are experiencing. Test the board to see if it is functioning properly.
  3. Check the wiring: The wiring between the control board and the incline motor may be damaged or malfunctioning, which could be causing the issue. Check the wiring for any visible damage or loose connections, and test it to see if it is functioning properly.
If you are unable to troubleshoot the issue using the steps above, or if you are not comfortable working with electronic components, it is recommended to seek the assistance of a qualified technician to diagnose and repair the treadmill.
1/4/2023 8:57:46 PM • Horizon Exercise... • Answered on Jan 04, 2023
2answers
Omega 3 treadmill - Does anyone know what might be
replace the old batteries (if your system have batteries, clean the contacts batteries) put a new ones.2) adjust the REED swtich see the diagram attached.3)tight the ribbon cables inside from display board and clean it. tight and clean the upper and lower connector. and try again.God bless you64554154-b7bd-4100-8a70-779a1727ba63.gif5b2cf7d6-545e-4e9e-80cd-605d4c8ca29d.gif
11/21/2022 6:15:24 AM • Horizon Exercise... • Answered on Nov 21, 2022
Horizon T101 stops suddenly display shows BELT,
Hi, Please check under your belt to see if there are any debris. Also, attempt to run your machine's belt without standing on it and see if the message comes on again. For more details, please check the troubleshooting section of your manual in order to determine if the machine needs servicing or maybe just some oil. Thank you.
11/10/2022 12:26:20 AM • Horizon Exercise... • Answered on Nov 10, 2022
Horizon t500 will start but speeds up on own and shuts down. I replaced the speed sensor already.
Resolution Check cables or loose wires. Double check that all connections are secure, especially the console cable. Unplug and reconnect the console cable at the top of the console mast - see the assembly instructions in the owner's manual for this step. Make sure the console cable is not pinched or damaged in any way. i hope this help!
11/8/2022 1:55:02 PM • Horizon Exercise... • Answered on Nov 08, 2022
2answers
Does anybody know a good fitness shop?
Dear Sir: You have the same risk, that if I recomend you.Please get the information from some relative, or friend about the experience for to buy some determined treadmills. Will be a good idea to buy from Sears.God bless you
10/21/2022 3:22:59 AM • Horizon Exercise... • Answered on Oct 21, 2022
Horizon T5000 treadmill stopped working.
Question edited for clarity. Question moved from Hoover Vacuums to Horizon Treadmill. You shorted out the motor control board, you need a new one, or the old one repairing. It does have a circuit breaker according to the parts diagram so try and find that. https://www.ereplacementparts.com/horizon-fitness-t500-tm30720082009-treadmill-folding-parts-c-201405_201552_201589.html Manual https://manualzz.com/doc/12277436/horizon-fitness-t5000-treadmill-user-manual ..
3/7/2022 7:00:40 PM • Horizon Exercise... • Answered on Mar 07, 2022
My quick speed keys - up or down wont work on my CT 81 horizon treadmill. Any advice?
I have the same problem on a model LS760T. Also the Stop button is inoperable.
2/21/2022 12:31:11 AM • Horizon Exercise... • Answered on Feb 21, 2022
Horizon T203 Treadmill Logo
Popular Tags
7 questions posted
Top Horizon Exercise & Fitness Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Horizon Exercise & Fitness
Most Popular Question
knocking noise
  • Exercise & Fitness
