20 Most Recent
ZT Group CISNET A7050 PC Desktop Questions & Answers
Internet Explorer is not working. What I can do
To reset Internet Explorer settings
Close any Internet Explorer or Windows Explorer windows that are currently
open.
Click to open Internet Explorer.
Click the Tools button, and then click Internet Options.
Click the Advanced tab, and then click Reset.
Select the Delete personal settings check
box if you would like to remove browsing history, search providers,
Accelerators, home pages, and InPrivate Filtering data.
In the Reset Internet Explorer Settings
dialog box, click Reset.
When Internet Explorer finishes restoring the settings, click
Close, and then click OK.
Close Internet Explorer.
Your changes will take effect the next time you open Internet
Explorer.
Notes
If you close all visible windows, but still get an error message
when trying to reset, you might have programs running that are not visible.
Restart Windows, open Internet Explorer, and
try resetting again.
If any of the categories fail to reset, it is because Internet
Explorer could not access a file or registry setting. This can be caused by
insufficient security privileges, files or settings being used by another
program, or low memory or high CPU usage. You can either continue to use
Internet Explorer without restoring these settings, or restart your computer and
try to reset again.
If you are using Internet Explorer on a server and have turned off
Enhanced Security Configuration or hardening (stronger security settings for use
on servers), reset will go to client-level security. You must reinstall
hardening if you want the increased security level. For more information on
Enhanced Security Configuration, see Enhanced Security
Configuration for Internet Explorer online.
I receive this message when I'm booting my CISNET
Your system is probably trying to boot from a USB drive. ZT systems for some reason will put USB hard drives ahead of drive 0 in the boot sequence. You can correct this in the BIOS. Another problem I had with mine is that the BIOS would not pick up the USB drives on a cold boot even though everything went fine with a restart. Cycling the power on the external after boot up solves this problem.
I am getting a message that there is no signal to
irst check the cable from the monitor is firmly connected to the graphics ports in the rear panel of the cpu tighten the two screws of the connector if you still have the problem then check the connector for any pin breakage if no pin breakage try adding an add on grapics card to the pci,agp or pci exp which is available in your motherboard if there is display then the problem is with connector in the motherboard
I have a Cisnet C-28 and I'm moving to Australia.
These used a variety of standard components so it is hard to give a precise anser.
HOWEVER if you check the rear of the computer and can see somthing similar to the one in the picture you will be fine as that allows you to select the correct volatage. Some PSU are also AUTO switching nd this will be on a label on the PSU itself (you may have to take the cover off the computer to see it)
Otherwise you can replace the PSU when you get there are most are a standardised form and any computer shop can do that for around $60 AU
Another method would be to check the local free ads when you get there and pick one up even cheaper.
Bob
Read the Cisnet AC adapter. It should say input:120-240V, 50-60Hz to work with 240v power anywhere in the world. You just need an outlet adapter for the country you're in.
Cannot access cisnet system recovery.
go here and get this utility called (ultamate boot CD) from here ok: http://www.mrbass.org/ubcd/
this will help you with you problem has many utilities it is free from this site an dit is an iso file so burn image to a disc and then put in the rom turn off PC and then restart and will boot the disc and do some of the diagnostics on the disc and find the problem ok good luck and have a nice day the fixist
Not getting sound out of
First you need to make sure that correct audio drivers are installed. Driver is a
piece of software that commands Windows how to use the hardware.
Click here to open the support page. Input your details and register; don't worry its free. The you will be presented with an option to input your product's serial number and a list of all available drivers.
Please note that this system comes with XP and it is possible that it may not have drivers for a newer system like Windows 7. In that case let me know the model of the motherboard and I will try to search for appropriate drivers.
I have a Cisnet model C-28 desktop computer. The
yes it can be replaced and i would recomend it on that model you can go to a local pc shop ask for one to be ordered or they my have one on the shelf if you want a cheep one try ebay they have good prices if this answer helps please rate it
