20 Most Recent
Kenmore 7.5 cu. ft. / 212 liter Upright Freezer 24701 Questions & Answers
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Will Freezer run overseas on a transformer?
Step Down Voltage Converters You can use this link to find a converter that should work. There are several other sites as well. You need to get a converter with enough wattage capacity to operate the freezer. I recommend you get one with a somewhat higher wattage rating than the freezer's wattage rating. For instance if the freezer is rated at 700 watts, I would get at least a 1000 watt converter. Good Luck !!! and Bon Voyage !
Door does not stay sealed when closed.
first make sure there is nothing inside stopping the door from closing , the freezer should be level, and the door should swing close on its own free will. the door can be tweaked by bending it back into shape .or by setting the top hinge bracket, it should have three 5/16 bolts, that will alow you to ''square the door''. but most of the time it's something in the way of the door.. look close and remove some items that you think might be in the way, then remove some more
I don't have a problem...
Hello, Thank You for using FixYa. I will be helping you today. No the unit will not work as a fridge.
Thank You and please rate my answer if it was helpful..
Error code b on kenmore chest freezer
LOW / NO BATTERY ALARM
The Low/No battery alarm will activate when the
power level of the battery becomes low. The display
will alternate between "b" (Battery, See figure 8) and
the cabinet temperature, the red alarm light will
become illuminated and the control panel will beep
every five seconds. To stop the audible alarm (beep),
press the "ALARM RESET" button. The red alarm
light will remain on and the display will continue to
flash until a new battery is installed. This same alarm
will activate if there is no battery installed
Where is the 9V battery located on a Kenmore upright freezer model 970
The location of the 9V battery on a Kenmore upright freezer model 970 can vary depending on the specific model and design. However, in general, the 9V battery is typically located in the control panel or on the back of the freezer near the compressor. You may need to consult the freezer's manual or contact Kenmore customer support for more specific information regarding your model.
