20 Most Recent Kenmore 14.1 cu. ft. / 399 liter Upright Freezer 24422 Questions & Answers
0answers
Kenmore upright freezer
I like pizza
8/19/2013 1:55:39 AM • Kenmore 14.1 cu.... • Answered on Aug 19, 2013
What kind of paint should I use inside the freezer
appliace paint get it at hardware store
8/18/2011 10:48:42 PM • Kenmore 14.1 cu.... • Answered on Aug 18, 2011
Where the coils inside are soldered together, we
These are painted with a silver paint that falls off over time, this is normal and not harmful. It will work just fine and be okay. The next time you shut it off to defrost it, you can clean the peeling paint off.
Kelly
3/24/2011 4:10:04 PM • Kenmore 14.1 cu.... • Answered on Mar 24, 2011
My freezer alarm goes every
maybe your door switch stock up try to replace or dismantle swicth .reset your alrm unplug the unit after several minutes. plug the unit observe operation.
2/13/2011 4:48:06 AM • Kenmore 14.1 cu.... • Answered on Feb 13, 2011
The freezer does not freeze
Please observe your thermostat setting and refrigerant liquids.
12/15/2010 7:52:03 PM • Kenmore 14.1 cu.... • Answered on Dec 15, 2010
My freezer worked fine i
dear sir/madam
please make sure your freezer,s compressor is working i think after transfer to another place it has been disconnected from electrical cable . so please contact to your service technician for further action .
hope answer the question
thank you
please vote!
9/14/2010 3:33:28 PM • Kenmore 14.1 cu.... • Answered on Sep 14, 2010
Will not run
just try to check up the relays in the compressor. or the wirings.
6/25/2010 4:24:53 PM • Kenmore 14.1 cu.... • Answered on Jun 25, 2010
What is the wattage??
just just look at the rear pannel of your freezer and you can find the wattage of your freezer.
6/25/2010 3:59:45 PM • Kenmore 14.1 cu.... • Answered on Jun 25, 2010
Not freezing
Common problems that would cause problem:
Compressor not running
inadequate power (less than 108v)
freon leaked out (not enough charge)
If available evap. fan not working
if available condenser fan not working
if avaiable defrost heaters bad
if avaialble timer out
if available bi-metal t'sat out
thermostat bad
thats about it. i wrote if available because you did not give a complete model number so i couldn't pull up a part list
hope this was helpful
4/2/2010 6:33:48 PM • Kenmore 14.1 cu.... • Answered on Apr 02, 2010
Kenmore 15 upright freezer
feel the fan motor to see if it is hot. If it is the fan motor is shot. Hope this helps.
9/26/2008 1:26:18 AM • Kenmore 14.1 cu.... • Answered on Sep 26, 2008
2answers
Stopped running
try putting on fast freeze. if it starts up this means thermostat is faulty. get back to me if you want
8/2/2007 4:56:44 PM • Kenmore 14.1 cu.... • Answered on Aug 02, 2007
Kenmore chest freezer cubic ft 253.16082108
19.7 cu. ft.
Kenmore 1608 - Elite 19.7 cu. Ft. Chest Freezer Use And ...
ManualsLib https://www.manualslib.com > manual > Kenmore-1608... View and Download Kenmore 1608 - Elite 19.7 cu. Ft. Chest Freezer use and care manual online. Use and Care Guide. 1608 - Elite 19.7 cu. Ft. Chest Freezer ..
4/10/2024 8:08:12 PM • Kenmore Freezers • Answered on Apr 10, 2024
2answers
Error code b on kenmore chest freezer
LOW / NO BATTERY ALARM The Low/No battery alarm will activate when the power level of the battery becomes low. The display will alternate between "b" (Battery, See figure 8) and the cabinet temperature, the red alarm light will become illuminated and the control panel will beep every five seconds. To stop the audible alarm (beep), press the "ALARM RESET" button. The red alarm light will remain on and the display will continue to flash until a new battery is installed. This same alarm will activate if there is no battery installed
2/18/2024 3:02:00 PM • Kenmore Freezers • Answered on Feb 18, 2024
Kenmore Upright Freezer Model #970180021 WB3285869Serial # I unplugged my freezer,plugged back said power interruption, I hit several buttons, Now flashing off, nothing else on panel lit up,thaw
try unplugging it and leaving it unplugged for a while. 15 minutes maybe? Leave door closed so it stays relatively cold. It should reset the unit.
2/8/2024 3:29:33 PM • Kenmore Freezers • Answered on Feb 08, 2024
Kenmore 14.1 cu. ft. / 399 liter Upright Freezer 24422 Logo
19 questions posted
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Freezers
  • Kenmore Freezers
Most Popular Question
freezer worked fine
  • Freezers
