20 Most Recent
HP Pavilion DV5-1000US Laptop Questions & Answers
The sound isn't working on my hp PAVILION LAPTOP
Right click on my computer go to properties then go to device manager if you have an air it will show up there as your driver is missing for your sound if your driver is missing and go to the website of the main facture of your computer possibly HP into your model and download does sound driver for your operating system
Hp pavilion dv5, flickering screen problem mostly
First restart the computer and tap f10 key on keyboard to enter bios, and check wethere the screen flickers or not you can even try to tilt the screen and check as the drivers doesnt works in bios screen ... if the screen flickers then it is a hardware issue .. if it doesnt then log on to safe mode with networking by pressing f8 as the notebook restarts and then go to device manager by typeing device at the start search and the uninstall the video driver and then reinstall it from hp.com support and drivers ..issue will be resolved if not then do a bios update from hp.com, support and drivers.
I have a hp pavilion
Change the cable.If keeps the same your mobo / cpu are bad.
If you need more help post back!
Thumbs and testimonial are welcome!
Have a dv5 1000us and after the bios and hp logo
Hi
when you say the screen is blank
what colour is the screen please
can you hear the laptop working
or do you think that it has switched itself off then
please also tell us what operating system you are running and is it the original factory fitted os
many thanks
Laptop powers up to hp logo and goes no further
Try removing the HDD if it works ROCK!if not try removing the WIFI card.If this dose not work than take it to a chip level repairing shop and get south bridge chip replaced.visit www.starwillfix.com for extimate and solutions.
Hi, i have an hp
I think the problem with your laptop is that the operating system on your laptop is corupt, that is why the windows is not responding.
I will advice you reinstall the operating system on your laptop, if the operating system can be reinstall, the windows should work fine and respond.
Take care.
Dv5-1000us wont turn on
First,
we need to make sure that the AC adapter & the laptop's power
receptacle are not the cause of the problem. In order to do this, please
refer to the following article for detailed diagnosis:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Next,
after we confirm that both the AC adapter & the laptop's power
receptacle are good, we will have to disassemble the laptop, one part at
a time, and after we remove each part, test to see if the laptop will
start or not. We should start by removing the hard drive, the CD/DVD
drive, the WiFi adapter, the modem, ... etc. It is also helpful to swap
the RAM modules with good ones to test, or if you have 2 RAM modules,
test the laptop with each of them one at a time.
If none of these works, your laptop's motherboard is defective & will need to be replaced.
Dv5 screen housing diassembly
I have taken apart several laptops, incuding an hp. usually the pastic cover pops off. the you will see the screws underneath.
Overheat and switches off automatically
check the cpu fan it is not working properly need clean sometime full of dast that why always became heat. epected of overheating is automatically shut down...
repair you cpu fan disasimble you laptop then check the cpu fan
thanks
After pluging in no power or power light
All of you have the same problem I have--the crazy thing won't boot up--blue lights but a dead, black screen. I've also had problems with the laptop becoming really hot. I've "resolved" these two issues by 1) setting the computer to never turn off. This works great until an auto-update of some program or other is necessary, usually in the middle of the night, and then a restart of the computer is necessary for the laptop to acknowledge the update. 2) When you turn on the laptop and all you get is blue lights on the keyboard, try this: Hold the power button on until the laptop turns off. Count to twenty and then holding the base of the laptop with both hands, turn it on its left side as you're holding it in the air, with the keyboard vertical instead of horizontal. While holding it in this position, push the power button. 99% of the time this will restart this crazy computer. I wonder if it's some kind of problem with the motherboard, but I am afraid to tinker with it. 3) Get yourself a laptop fan to help draw off the excessive heat so you don't cook your laptop. These HP model is prone to overheating and other issues, so we all have to band together to help one another overcome all its idiosyncracies. While all this is not a solution, it'll at least help you limp along until you can come up with a better answer. What have you got to lose at this point?
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
