20 Most Recent
HP Pavilion DV6910US Laptop Questions & Answers
WHen I hook my laptop
no laptop stated ok W7 OS, nice to know.
hopeless?
nor external model screen stated
try a different external screen
any shop can fix it, ask them
no need to ship anything
get it checked out by a technician
we can test all 3 parts and tell you whats worn i minutes.
i can not understand your post
try to be more clear
does local LT screen work ok
does using a known directly connected screen (VGA)
on the LT you must turn on external screen using the fn hot key
the the external works,. do so, now
if both internal and external fail the LT is bad, guess, bad GPU chip
if only external fails, try a known working external screen
if that works your external is bad.
the docking is last, and if only it fails, then ITS BAD.
Averatec 2500 Series Webcam Not Working
That's a registry fault and you have to go to your device manager. Ensure the device is set as active and run the system troubleshooter to ensure none of the dll's in the driver base have been corrupted.
My hp pavalion dv6910 dvd/cdw driver is missing
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
My kitten loves to sit
Try to press all of keys on your keyboard with some pressure and start your laptop again.
Thanks
As of this morning, I
righclick my computer then properties then hardware then device manager and expand the audio vedio games controlleor if you see a yellow question mark reinstall the driver
I have a HP Pavilion dv6910us laptop. My cd/dvd
If you don't see it in the device driver, then it doesn't exist.
Go to the HP website and search for 'download drivers'... There will be a place where you can type in the driver you're looking for. Download and install. That should fix your problem.
This problem has nothing to do with itunes or filters.
--Crazy PC Lady
Bootmgr is missing startar ej vad att göra?
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully.
8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
While my computer is bootup
Try starting up in safe mode and see what happens, before the windows logo comes up reapeatedly tap on F8 so you get advanced start up options on the screen, select safe mode, and wait until the computer starts up.
in safe mode does the problem persist? does it happen after a certain amount of time? if you just leave the computer for example to the Bios settings (f2 or f1 or DEL) button to enter bios setup right when the power is on, does the picture go black on its own eventually?
I have hp laptop with AMD Turion 64 x2 modle no
You are missing the drivers for your laptop. Click on the link below to select your operating system and once you press go you will be given a selection of drivers. Just download and install the ones you need.
Click here for drivers
I've lost my D:Drive's Data.
You'll have to check to see if hp.com has the drivers for your computer available for download.
You may have to input the computer's model # dv691ous.
COMPUTER: HP DV6910us
Sounds like faulty CPU fan / Mobo fault. Needs Tech to decide. Either will need complete strip down of Laptop.
Get quote first.
I have a hpg60-235dx notebookpc it has abuilt in
1-its a web cam
2-you can use it with yahoo messenger msn messenger
skype messenger
in control panel go to scaners and cameras
It should show the cam click on it and it should start
and you should see yourself
I surely hope this has helped you
Good Luck with your cam
Happy Computing
