20 Most Recent
Dell Studio 17 Notebook Questions & Answers
I have a dell studio
This is due to loose connection which could happen after a period of time between the screen to the laptop.
Solution:
You can use another LCD screen as you secondary screen which you need to hook up to your laptop onto the blue connector (vga connection) or get the laptop screen replaced altogether
How to switch touchkeys on
Click start button and in the search field type; quicksetOnce the program is displayed, double click the quickset application to run the program.
Just updated Windows 7 on Dell Studio laptop
was that an pirated os or such??/
i am myself using dell studio 17
i had home premium and then i installed 7 ultimate 64 bit i got the same error...
go to boot menu and select hdd as first boot device
My laptop says boothmgr is
Insert your recover disc when you start the computer and if it asks you to hit a key to boot from DVD do so and select start up repair or boot repair and let it do it's thing. Should fix it for you.
The disc drive will not hold a disc, it is
Try rebooting the system and insert the disk again. If this does not fix the problem, it may be a case of taking it to the local computer repair shop unfortunately as the most probable problem is a hardware issue, which could mean that a replacement drive is needed. If you possess an external DVD drive try using that.
Brand new dell studio 17; I get a pure white
okay... so do this steps to fix it.
1. on the desktop..click on start and in the start search box type MSCONFIG and then press enter or click on SYATEM CONFIGURATION UTILITY then a window will open in the middle. you can also type this in the RUN box if using XP.
2. Click on STARTUP at the top right side.
3. You would see some check boxes. Click on DISABLE ALL at the bottom right hand side.
(all the boses shall become uncheck)
4. Click on APPLY and the close it.
5. Click the check box for DONT SHOW THIS MESSAGE AGAIN.
6. RESTART the computer.
7. Issue resolved. :)
I have a question about my dell studio laptop 17in
sounds like something is wrong with the loading sequence. if u have the installer disks that came with the computer. u can run repair with the opperating system install disk. if that doesnt fix it try reinstalling the os .( you'll have to erase everything on the harddrive and will lose everything) and if that dont work then it is probably the harddrive itself and my need to b replaced
My Dell Studio 17 just randomly shuts down.
have a look to see if there is much dust around the fan and if so this will need to be cleaned out. if there is dust then your dell is shutting down because it is getting to hot.
Dell Studio 17 laptop : keyboard response
Possibly a failed keyboard (was there a liquid spill?), loose keyboard cable or failed system board. Call Dell support, if your warranty is expired keyboard should be about $40-75, system board can be $200-600 depending on model and availiability of the part.
What are the functions of the keys on the dell
Fn + F1
Change Display Device.
Fn + F2
Wireless Control
Fn + F3
Battery information
Fn + F4
Decreases brightness on the integrated display only (not on an external
monitor).
Fn + F5
Increases brightness on the integrated display only (not on an external
monitor).
Fn + F6
Keyboard backlit(available only if a backlit keyboard is
installed)
Fn + F7
Mute
Fn + F8
Decrease audio Volume.
Fn + F9
Increase audio Volume.
Fn + F10
CD Previous - Play previous media file.
Fn + F11
CD Play/Pause - If there is Audio CD in system, Media player will play
music.
Fn + F12
CD Next - Play next media file.
Sudio 17 spontaneously shuts off
Troubleshooting With PSA Diagnostics on a Laptop Computer
STEP: Run the Preboot System Assessment (PSA)
Additional Information
Ensure that the computer is powered off.
Press and hold <Fn> and press the power button to power the computer on.
Release both buttons. The PSA diagnostics sequence begins.
Make note of any PSA beep codes or PSA error codes
- check PSA error code on support.dell.com
