20 Most Recent
Pyramid Alloy Mountain Bike Dual Cable Brake Lever Questions & Answers
My locking dual brake lever
If the lever stays in the park position but doesn't hold the wheel, then you'll need to have the brakes adjusted. They're likely not properly aligned with the rim, which is why the cables are tight, but not effective.
I cant ballence
This is no easy problem to fix. Suggestions, however, i will offer.
1. Contrary to what seems right, moving slowly is NOT helpful. Moving slowly is an advanced technique that comes with time. Go as fast as it takes to feel comfortable; sometimes faster IS better.
2. Look ahead, not down. Look where you want to go, not where you don't want to go.
3. Loosen up. The more tense and worried you are about maintaining balance, the more likely you are to fall. Breathe easily and believe you can stay up.
4. Pick a spot to practice where you can fall easily. Grass on the sides is good, but not trying to ride in the grass, because it bogs down your speed.
5. Wear padding until you feel confident you will not be falling any more.
6. Find someone else to practice with. It helps when someone who is a good rider is there to encourage and critique you.
Hope this helps a little,
matt
Tomahawk E Series Exercise bike loud peddling sound
Standard WD40 is just a 'quick fix' as it isn't an actual oil unless the can is clearly labelled as "Bike All Condition Lubricant". It'll be best to buy a proper light oil like 3in1, 151 Super oil or an actual chain lube.
This 'clickey' noise. Is it random and happening every so often or is it a constant, regular click that changes with the speed your pedalling at? Check for slack in the chain. as you wiggle the chain up and down there should only be about a centimetre of movement in the chain. If it's too slack or too tight it can make strange noises. Check the axle bolts and nuts to make sure they're not loose. Check the wheel is mounted straight. If it's turned left or right the chain will 'skip' as it's slightly missing the cog teeth on the wheel. Use the frame at the rear end of the wheel as reference and measure how far the side of the wheel is from the frame on both sides. It should be about the same both sides.
9/22/2023 12:16:04 PM •
Cycling
Answered
on Sep 22, 2023
New Balance 6100 Recumbent Bike making a clanking noise when pedaling
I have done a tremendous amount of research on this problem. New Balance (Fitness Quest) is out of business as of late 2012 and no parts are available. The main bearing or crank bearing set is 100% compatible with Proform part number 295560. Since New Balance put their name on this product, they have stated they will reimburse customers for the repairs.
4/5/2023 11:21:09 AM •
Cycling
Answered
on Apr 05, 2023
A manual for a manual for a Genesis model gs52686 men's bike a V2 100
Il est possible de trouver un manuel pour le v?lo Genesis GS52686 V2 100 en visitant le site web du fabricant ou en contactant directement le fabricant pour demander un manuel. Il est ?galement possible de trouver des informations sur ce v?lo sur des forums de discussion ou des sites web sp?cialis?s dans les v?los. Il est recommand? de v?rifier si le manuel est disponible en ligne ou de demander une copie imprim?e aupr?s du fabricant. Il est important de noter que les r?glages de la fourche de suspension et de la suspension arri?re peuvent varier en fonction du poids, de l'exp?rience et des pr?f?rences de conduite de chaque cycliste. Il est recommand? de consulter un m?canicien ou un expert en v?los pour obtenir des conseils sur les r?glages appropri?s pour votre v?lo.
3/14/2023 6:23:13 AM •
Cycling
Answered
on Mar 14, 2023
