20 Most Recent
Yakima Sks Lock Cores Questions & Answers
I have two different SKS cores. One for my
You have to replace the SKS cores you don't want with mates to the ones you do want.
I would suggest replacing the snowboard cores with ones that are the same # as your towers since then you are only replacing 2 cores instead of 4 and it is cheaper.
The key should have a number on it that tells you what core it goes too. You can either contact yakima and get the exact cores you need or go into your local dealer and see if they have them in stock or can order for you.
Need installation manual and mounting
The main web page for Yakima Products, Inc. provides a search feature that will match up the rack model you need for your particular car. They will also be able to supply a manual for any model they sell. Included is the website link!
http://www.yakima.com/
Tomahawk E Series Exercise bike loud peddling sound
Standard WD40 is just a 'quick fix' as it isn't an actual oil unless the can is clearly labelled as "Bike All Condition Lubricant". It'll be best to buy a proper light oil like 3in1, 151 Super oil or an actual chain lube.
This 'clickey' noise. Is it random and happening every so often or is it a constant, regular click that changes with the speed your pedalling at? Check for slack in the chain. as you wiggle the chain up and down there should only be about a centimetre of movement in the chain. If it's too slack or too tight it can make strange noises. Check the axle bolts and nuts to make sure they're not loose. Check the wheel is mounted straight. If it's turned left or right the chain will 'skip' as it's slightly missing the cog teeth on the wheel. Use the frame at the rear end of the wheel as reference and measure how far the side of the wheel is from the frame on both sides. It should be about the same both sides.
9/22/2023 12:16:04 PM •
Cycling
Answered
on Sep 22, 2023
New Balance 6100 Recumbent Bike making a clanking noise when pedaling
I have done a tremendous amount of research on this problem. New Balance (Fitness Quest) is out of business as of late 2012 and no parts are available. The main bearing or crank bearing set is 100% compatible with Proform part number 295560. Since New Balance put their name on this product, they have stated they will reimburse customers for the repairs.
4/5/2023 11:21:09 AM •
Cycling
Answered
on Apr 05, 2023
