20 Most Recent Falcon Micargi GT 26" Beach Cruiser Questions & Answers
How to install the rear fender without scratching
Take the wheel off first.
4/10/2010 12:29:47 PM • Falcon Micargi ... • Answered on Apr 10, 2010
Strip the rear brake assembly
Go to parktool.com. Bicycle specific tools are required for this repair.
5/22/2009 12:47:36 PM • Falcon Micargi ... • Answered on May 22, 2009
Falcon Olympic serial number x47372 isthis 531 renolds an what year is this bicycle
Just Google Falcon Olympic bicycle, as the only way anyone on this site can likely answer your question is by doing the same thing. By doing it yourself you are far more likely to get the info you want, especially as you provide no picture, description, or which parts/components are on the bike. For more guidance see my Tip: How to determine the year value etc of your bicycle I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
12/2/2016 3:46:44 AM • Falcon Cycling • Answered on Dec 02, 2016
0answers
0answers
0answers
I had to take off
By the "gear arm" I assume you mean that part of the rear derailer that the chain zig-zags through. This arm moves in two ways. It moves in and out (toward the wheel and away) as you move the shift lever - which is how it changes gears, by moving the chain onto different sprockets (gears). It also moves forward and back (toward the front and back of the bike) under spring pressure. This forward and back motion is necessary to take up the slack in the chain when you are using the smaller sprockets (the smaller the sprocket, the "higher" the gear). When the wheel has been removed, this arm moves forward (under spring pressure) as far as it can to take up all of the slack in the chain. All you have to do is grasp this lever and pull it toward the back of the bike, allowing the lever and the chain to pass behind the sprockets (gears) as you pull the wheel back into it's position. You can safely pull this arm forward and back at any time without doing any damage. One more tip-- I find it a little easier if you first put the shift lever in a "middle" gear position. Then when you pull the wheel into place, you should aim to put the chain on a middle sprocket. You don't have to hit the exact correct sprocket as you can simply lift the rear wheel and turn the pedals forward (after installing the wheel) and the chain will move to the correct sprocket corresponding to the setting on the shift lever.
Good luck! Please vote if you found this helpful. Al K
10/14/2010 12:41:09 PM • Falcon Cycling • Answered on Oct 14, 2010
Why isnt my stem for
Your handlebar stem has to be inserted at least 2 1/2 inches or else it can snap and it is tightened at the stem bolt at the top. Why are you trying to tighten it at the bottom?
9/25/2010 2:47:35 PM • Falcon Cycling • Answered on Sep 25, 2010
Why cant I change gears on my bike?
Have you tried the use WD40 or GT85 Lubes on the seized parts? This is usually enough to free this sort of problem.
3/15/2010 11:24:49 AM • Falcon Cycling • Answered on Mar 15, 2010
2answers
What size is the seat post on the Next px 6.0 bicycle?
The Next PX 6.0 uses a 27.2mm seat post.
1/1/2024 12:50:08 PM • Cycling • Answered on Jan 01, 2024
My gt mach one serial number is SA8Y01976 NEED TO KNOW THE YEAR AND WHERE WAS MADE
serial number is 12900243GT m one. Can anyone tell me the year?
10/24/2023 4:03:47 PM • Cycling • Answered on Oct 24, 2023
3answers
Where can i get a left paddle for my Mongoose XR-75 Mnt. bike?
clean your garage and you will have it. or try bike shops.
10/5/2023 4:17:26 PM • Cycling • Answered on Oct 05, 2023
My bicycle's pedal moves before the wheel. I tried reassembling the chain and the wheel. P.s my bicycle doesn't have a mechanical gear
If your bicycle doesn't have mechanical gears, the issue might be related to the freewheel or cassette, depending on your bike's specific setup.
10/3/2023 10:24:25 AM • Cycling • Answered on Oct 03, 2023
Tomahawk E Series Exercise bike loud peddling sound
Standard WD40 is just a 'quick fix' as it isn't an actual oil unless the can is clearly labelled as "Bike All Condition Lubricant". It'll be best to buy a proper light oil like 3in1, 151 Super oil or an actual chain lube. This 'clickey' noise. Is it random and happening every so often or is it a constant, regular click that changes with the speed your pedalling at? Check for slack in the chain. as you wiggle the chain up and down there should only be about a centimetre of movement in the chain. If it's too slack or too tight it can make strange noises. Check the axle bolts and nuts to make sure they're not loose. Check the wheel is mounted straight. If it's turned left or right the chain will 'skip' as it's slightly missing the cog teeth on the wheel. Use the frame at the rear end of the wheel as reference and measure how far the side of the wheel is from the frame on both sides. It should be about the same both sides.
9/22/2023 12:16:04 PM • Cycling • Answered on Sep 22, 2023
Falcon Micargi  GT 26" Beach Cruiser Logo
3 questions posted
Top Falcon Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Falcon Cycling Expert? Answer questions, earn points and help others
View Most Popular
Falcon Cycling
  • Falcon Cycling
Most Popular Question
strip rear brake assembly
  • Cycling
