20 Most Recent
Kenmore 32212 Bagged Upright Vacuum Questions & Answers
Broken
most of the kenmore upright cleaners use the panasonic upright belt so you may fined them at your vac shop or local hardware store,home depot
Removing and installing the pedal in kenmore upright vacuum cleaner - part no. 8174906; model no. 116.31912100
I don't have specific information on the Kenmore upright vacuum cleaner model number 116.31912100 or the part number 8174906, but I can provide you with general guidance on how to remove and install pedals on some vacuum cleaner models. Keep in mind that procedures may vary between models, so use the following as a general guide:
Removing the Pedal:
- Unplug the Vacuum Cleaner: Ensure the vacuum cleaner is unplugged to prevent any electrical accidents.
- Turn the Vacuum Cleaner Over: Lay the vacuum cleaner on its back so that you have easy access to the underside.
- Locate the Pedal Assembly: Identify the pedal assembly on the underside of the vacuum cleaner. It is usually connected to the height adjustment or other features.
- Release Tabs or Screws: Look for tabs or screws securing the pedal assembly in place. Use a screwdriver or the appropriate tool to release these tabs or screws.
- Disconnect Linkages: Some pedal assemblies are connected to linkages that control various functions. Disconnect any linkages carefully.
- Remove the Pedal Assembly: Once the tabs, screws, and linkages are disconnected, carefully remove the pedal assembly from its housing.
Installing the Pedal:
- Position the New Pedal: If you are replacing the pedal, position the new pedal in place.
- Reconnect Linkages: If your vacuum cleaner has linkages, reconnect them to the appropriate points on the new pedal assembly.
- Secure the Pedal: Use screws or tabs to secure the new pedal assembly in place. Make sure it is securely fastened.
- Test the Pedal: Manually operate the pedal to ensure that it moves smoothly and engages the desired function.
- Turn the Vacuum Cleaner Upright: Once the pedal is securely in place, turn the vacuum cleaner upright and plug it back in.
If you're uncertain about any steps or encounter difficulties, it's recommended to consult the user manual for your specific model or contact the manufacturer's customer support for assistance. They may provide detailed instructions or guidance tailored to your vacuum cleaner's model and part.
Hose assembly model # on 11621714110
The hose assembly model number 11621714110 is a genuine OEM (Original Equipment Manufacturer) part for use with a variety of appliances, including vacuum cleaners and washing machines. This hose assembly may be used to connect various parts of the appliance, such as the pump and the tub, or to connect the appliance to a water source.
I hope this information is helpful! Let me know if you have any other questions.
Light and brush roll stopped working on Kenmore cannister
There is a connector somewhere in the bottom that will have gotten debris and stuff in it. Unplug the power first then clean it all contact pins that transfer power. Compressed air works the best but the effect can be gained by using a toothpick. Clearing out the connectors should restore the power to the head. If one or the other stops then its a different problem. This seems to be a full failure in the elements of the head that require power. DO NOT WORK ON ANYTHING STILL PLUGGED IN!!!
