20 Most Recent Monark Fitness Cycle Questions & Answers
The steel on the crank arm of my Monark 817e exercise bike broke, how do i remove it, it has no cover/nut/bolt/washer holding it to the axel
It's very difficult to find someone familiar with a particular model of a particular brand of exercise bike, but I pulled up some pics that seem to show that yours can have one of two types of crank. One is called a "one-piece" crank. Typically it is removed by unscrewing parts from the left side after removing the left pedal (left-hand/reverse threads). You may have to remove the housing to access and remove the parts. The other is a 3-piece cranks, and the arm will have a plastic cover at the axle. If you remove that dust cap you will see a bolt underneath. One has to remove that bolt and then use a specialized tool (crank extractor) to remove the crank arm. Check with a bike shop (take in the unit or take some good pics) for replacement. I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
8/5/2016 3:05:15 AM • Monark Cycling • Answered on Aug 05, 2016
2answers
What years did they make the Monark model 2280 bicycle?
this web site should help you.http://www.nostalgic.net/monark-bicycles If you need further help, reach me via phone at https://www.6ya.com/expert/cynthia_0eebb7da17b33b5e
5/2/2015 8:46:24 PM • Monark Cycling • Answered on May 02, 2015
Serial numbers sk50-6 2882
Who is the manufacturer?
11/24/2014 5:28:04 AM • Monark Cycling • Answered on Nov 24, 2014
0answers
0answers
0answers
0answers
2answers
What size is the seat post on the Next px 6.0 bicycle?
The Next PX 6.0 uses a 27.2mm seat post.
1/1/2024 12:50:08 PM • Cycling • Answered on Jan 01, 2024
My gt mach one serial number is SA8Y01976 NEED TO KNOW THE YEAR AND WHERE WAS MADE
serial number is 12900243GT m one. Can anyone tell me the year?
10/24/2023 4:03:47 PM • Cycling • Answered on Oct 24, 2023
3answers
Where can i get a left paddle for my Mongoose XR-75 Mnt. bike?
clean your garage and you will have it. or try bike shops.
10/5/2023 4:17:26 PM • Cycling • Answered on Oct 05, 2023
My bicycle's pedal moves before the wheel. I tried reassembling the chain and the wheel. P.s my bicycle doesn't have a mechanical gear
If your bicycle doesn't have mechanical gears, the issue might be related to the freewheel or cassette, depending on your bike's specific setup.
10/3/2023 10:24:25 AM • Cycling • Answered on Oct 03, 2023
Tomahawk E Series Exercise bike loud peddling sound
Standard WD40 is just a 'quick fix' as it isn't an actual oil unless the can is clearly labelled as "Bike All Condition Lubricant". It'll be best to buy a proper light oil like 3in1, 151 Super oil or an actual chain lube. This 'clickey' noise. Is it random and happening every so often or is it a constant, regular click that changes with the speed your pedalling at? Check for slack in the chain. as you wiggle the chain up and down there should only be about a centimetre of movement in the chain. If it's too slack or too tight it can make strange noises. Check the axle bolts and nuts to make sure they're not loose. Check the wheel is mounted straight. If it's turned left or right the chain will 'skip' as it's slightly missing the cog teeth on the wheel. Use the frame at the rear end of the wheel as reference and measure how far the side of the wheel is from the frame on both sides. It should be about the same both sides.
9/22/2023 12:16:04 PM • Cycling • Answered on Sep 22, 2023
Monark Fitness Cycle Logo
2 questions posted
Top Monark Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Monark Cycling Expert? Answer questions, earn points and help others
View Most Popular
Monark Cycling
  • Monark Cycling
Most Popular Question
rpm not read accurately monark 828e
  • Cycling
