I just received the manual via PDF. Doesn't look like I can attach a file to this, so contact me with your email address. It is for the regular carrier, but they go together the same.
There are several ways to install a child carrier on a bike, depending
on if it attaches to the rear derailleur or to the back of the frame. First check this instructional video about how to install the rack...
So, installing a baby seat on a bicycle typically involves a basic rack assembly and a clipping in of the safety bar. Find out what equipment is needed to work on baby seats with help from an experienced bicycle mechanic in this free repair video on installing child bike seats: Video-Install-Child-Bike-Seat.
Well, the lock is not any good if you don't know the combination, but for a barrel-type combo lock, if you accidentally turned the numbers while open just push the male end in and turn the 1st ring until it goes in slightly. Then turn the next ring and so forth until it's all the way in. Now you can see the combination. I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Hook a chain up to the rear on it, connect the other end of the chain to the bumper of your truck, rev engine to 6,000 rpm, put in reverse, hold on for dear life.
Hi. It could be you're puting in too much air. Check pressures. 2) check valve that it is tight in and sealing properly. Note: When you travel on hot pavement the pressure will rise so put the proper air in. It maybe written on tire sidewall. Max PSI ..... Good luck.
