20 Most Recent
Freestyle Mongoose Bmx & Owners Manual - Bike / Bicycle Questions & Answers
Need to read owners manual for samsung wf218an
WF218ANB: http://www.samsung.com/us/support/downloads/WF218ANB
WF218ANB/XAC: http://www.samsung.com/us/support/downloads/WF218ANB/XAC
WF218ANW: http://www.samsung.com/us/support/downloads/WF218ANW
3/1/2019 1:30:35 AM •
Freestyle...
Answered
on Mar 01, 2019
How to install front tire of mongoose bmx
Remove wheels, remove valve stem from innertube. remove tire by getting tire edge over rim. reinstall in opposite direction. If this seems difficult consult local bike shop for assistance
12/4/2014 6:49:57 PM •
Freestyle...
Answered
on Dec 04, 2014
Cs20608297
Its a Mongoose, made by Pacific Cycle. Check Mongoose.com for more help.
11/5/2014 8:17:35 PM •
Freestyle...
Answered
on Nov 05, 2014
How to adjust brakes on the mongoose mode 100
Two places for adjustment. First is at the end of the brake lever. This is the minor adjustment. The second is the major adjustment, its located at the brake. For this one, you'll need some tools. The cable need to be loosened, then with a pliers the slack in the cable is removed and the bolt is retightened. You may want to take it to a bike shop for this repair.
10/14/2014 8:32:52 PM •
Freestyle...
Answered
on Oct 14, 2014
How to stop my grips
Put the grips in hot soap'water let them soak .take them out let cool off clean and rinse them off with luke warm water after cleaning them also inside the grip hole, clean the handle bar with alcohol. Put them back on and twist them till they become a bit stiff than let it dry. It will grip the handlebar.
12/13/2012 6:45:22 AM •
Freestyle...
Answered
on Dec 13, 2012
How do you remove the
if i remember correctly it is a 15 mm socket for a ratchet that is the tool that i use at the shop
7/11/2011 2:50:31 AM •
Freestyle...
Answered
on Jul 11, 2011
The handle bars will not keep straight?
You may have a stripped stem bolt, and need to replace it. Also, I hope that you use metric allen wrench because all bikes are metric. Take it to a bike shop and they should be able to set you up for a very nominal fee.
9/27/2010 3:42:58 PM •
Freestyle...
Answered
on Sep 27, 2010
Mongoose bmx
The info and other good advice is on this site:http://www.bikeguide.org/how-to/brakes/brakes.php
9/11/2009 1:43:58 AM •
Freestyle...
Answered
on Sep 11, 2009
Describe your Freestyle Mongoose Bmx &
Here are some sites that might help:http://www.bmx-forum.com/showthread.php?t=21326 and http://www.parktool.com/repair/readhowto.asp?id=127 and http://www.ehow.com/video_2347393_bmx-bike-headset-repair-tips.html and http://www.youtube.com/watch?v=611Dfk-pBd8 Hope these help.
9/1/2009 2:16:25 AM •
Freestyle...
Answered
on Sep 01, 2009
